Muffler or Not, That is the Question.
Muffler?
Poll ended at Wed Mar 08, 2006 10:03 am
Yes
3
50%
No
3
50%
Total votes: 6
Postby Bill Edmundson » Wed Mar 01, 2006 10:03 am
I'm building an inboard runabout. I'm going to use a 125 hp diesel. I'll be in and out of a condo/marina. I've seen pictures both ways. I don't care to be loud. I'm told the Yanmar I've picked is "quiet". The muffler in the West Marine catalog is so large it would be a problem.
Problems, Problems, Problems.
JF Woodworks
Postby JF Woodworks » Wed Mar 01, 2006 11:33 am
Bill,
Based on the information you provided and looking at the Yenmar website and the 125hp JH series engine I would say no muffler as they claim whisper quiet engine operation, you also seem to imply that you don't have the room for one anyway. I tried the poll but nothing happened when I clicked No.
http://www.yanmarmarine.com/products/product_jh.php
Postby Bill Edmundson » Thu Mar 02, 2006 9:15 am
Thanks for the comment, Matt.
A little more info:
This boat is mid engine with a cockpit behind the engine.
Exhuast is 3" at the engine.
A single muffler would be 5" pipe w/muffler 11" dia. x 30" long.
Twin mufflers would be 3 1/2" pipe w/mufflers 8" dia. x 23" long.
Or, twin muffles 4" pipe w/muffler 8 3/8 " dia. x 17" long.
That's a lot of real estate at a point where the boat is about 5' wide inside.
BTW, Matte: My next project is now a console skiff. Thanks alot!
JF Woodworks
Postby JF Woodworks » Thu Mar 02, 2006 1:42 pm
So Bill could any of those options work if you only have 5 inches of clearance? My thought is if you don’t need it as Yenmar suggests why spend the extra money and aggravation. Good Luck what ever you decide.
Postby Bill Edmundson » Thu Mar 02, 2006 6:25 pm
I'm probably not going to use one. But, I'll try not to block myself out. So, if I change my mind later I won't distroy the boat.
Thanks for the input.
Bill :D
Postby kens » Thu Mar 02, 2006 11:01 pm
I believe that when Yanmar says "quiet" engine, they really mean it is a quiet diesel as compared to a Detroit , Caterpiller, or industriel Cummins. Quiet meaning quiet valves, quiet diesel injection and combustion. I still think the exhaust note could not be made quiet without a muffler.
Dwain the ski king
Postby Dwain the ski king » Sun Mar 19, 2006 12:11 am
If you are running a "wet"exhaust, don't worry about being to loud. I have a 283 Chevy in my Ski King with 3" diameter pipes and use no muffler. The water passing thru the exhaust does a fine job of muffling, in fact I was disapointed in the sound level. I like-em to be heard....Dwain Colton, AKA, Skiking.......
Postby Bill Edmundson » Mon Mar 20, 2006 10:55 am
Dwain & kens,
Thanks for the input. As you can tell, it is about an even split on the question. When I mentioned a muffler the dealer looked at me like I was nuts. He said if I did use one that I should go up a size on the exhaust. They would check back pressure at sea trial.
