Gentry in Minnesota
khundley
Re: Gentry in Minnesota
Post by khundley »
Beautiful!
Ken Hundley
- Stevie Ray Vaughan
red
Post by red »
congrats youve built an awsome boat
steveh41
Post by steveh41 »
Fantastic build! Looks very elegant on the water.
Andy Garrett
Post by Andy Garrett »
Simply awesome!
Andy Garrett
Gayle Brantuk
Post by Gayle Brantuk »
Congratulations on a very beautiful boat!
leakcheck
Post by leakcheck »
I don't want to gush like a little girl but...well, okay I do want to ...damn that is soooooo sweet!! You are the master! Who's your daddy? I would just sit in the garage and stare at that beauty!!!!
STeve
Congrats!!! :!: :!: :!: :!: :!: :!: :!: :!:
trisailor
Post by trisailor »
thanks everyone, even though the time on the water was fairly abbreviated, it sure was worth the effort to get it INTO the water before the fall weather became winter. (forecast- Fridays high 39 degrees, low in the 20s thru the weekend).
I believe the boat is going to be a sweetheart to drive next year. The tranny and carb glitches should be solved, and the boat should have its fit and finish completed.
it seem gently soft through the few wakes it managed, corners predictably, and certainly responsive in the take off. can't wait to give it some more strenuous trials next May (or April, if I wear my parka)
I'm trying to post a couple more pics from last Sunday, but they don't seem to want to upload this morning.
trisailor
Post by trisailor »
a beautiful fall day
trisailor
Post by trisailor »
at the dock and from a distance
Look's like she rides as good as she looks!!! Good Job!!!
Roberta :D :D :D :D :D :D :D
Post by neel thompson »
Really nice Dean.....You did a great job, and she is beautiful. Way to go !!! G7??
Gayle Brantuk
Really beautiful! Congratulations....
trisailor
Post by trisailor »
I put the dust cover over the boat after the launch in late October. A couple days ago, I decided to take it off and start working on the upholstery. Thought a few in process shots of the front seat might be in order.
laying out the pleated back panel
first stitches
first stitches
sewing close to the folded stitch line
trisailor
Post by trisailor »
then the seat bottom. I decided to break up the front seat into two cushions. I cut two pieces of plywood to the shapes I wanted. The fabric is cut to that shape. After sewing it up I pulled the cover over the plywood and stapled it on the bottom. Then those two pieces are screwed to the longer plywood bench seat, using t-nuts. So far so good.
laying out the cut pieces before sewing
cutting little notches on the inside seam to allow sewing a curve without bunching
after sewing, before pulling it over the plywood
Really NICE!!! Great you can do your own upholstery.
