It is currently Fri May 24, 2013 2:17 am
Post new topic Reply to topic  [ 339 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 23  Next
 Post subject: Re: Gentry in Minnesota
PostPosted: Tue Jul 17, 2012 9:21 am
trisailor,
Beautiful boat! Thanks for posting the photos--look forward to seeing more! Ken Hankinson wrote an article about trailers that may shed some light on this subject:
http://boatbuilders.glen-l.com/1005/build-your-dream-boat-17/
Hope that helps...
Gayle Brantuk
Vice President
Glen-L Marine
Visit our Blog & Create Your Own!
PostPosted: Tue Jul 17, 2012 10:18 am
thanks Bob, and I'll bet you are 10 degrees warmer than me, being located farther south. thanks Gayle, for the link
PostPosted: Wed Jul 18, 2012 6:15 pm
time for some dashboard work, while the varnish is drying. instruments and switches first, then the wiring
File comment: frontside
File comment: backside
PostPosted: Thu Jul 19, 2012 3:46 am
How long are you waiting between varnish coats? How are you applying the varnish? Sanding between coats? It won't be long now. Better get those oar locks installed !!! Looks great Dean....... Neel
PostPosted: Thu Jul 19, 2012 4:47 am
Hi Neel- from the product description: "Epifanes Wood Finish Gloss varnish works especially well on Teak wood. No sanding between coats is required. This is the perfect alternative to traditional varnish as it eliminates all that sanding and repetitive care."
SO, I figured, for the initial grain-filling portion part of the job, this would the clear ticket. Brush it on. Wait 24 hours or until dry, then brush on another coat. NO SANDING between coats! (maximum wait time between coats is 72 hours) The fourth coat, which I will apply today, will be the traditional Epifanes gloss varnish. Wait 'til tomorrow or the next day and I will then carefully sand the surface smooth and flat. I say carefully, as all exposed wood colors are a stain and I want to make sure I don't sand into (or through!) that layer.
Then I will SPRAY another coat of Epifanes Wood Finish Gloss varnish, followed by a coat of Epifanes Clear Gloss varnish. Sand that.
Repeat that cycle one more time.
Then spray on my final coat of gloss varnish and call it a good time.
At least that's the plan!
Then it will be time to put the boat back together. So far, I really like this product.
Bought a decent 2 1/2" badger hair brush. Between coats, I keep the brush suspended in a covered can, filled with kerosene past the bristles. Rinse the brush 3 times in mineral spirits before and after varnish. Fast clean-up, no dust problems resulting from a dried out brush.
PostPosted: Thu Jul 19, 2012 3:16 pm
I have 2 sets of bunks, one set is bow bunks, the best trailer I ever have. I wouldn't have a trailer without the bow bunks.
PostPosted: Thu Jul 19, 2012 3:21 pm
trisailor - what are you using to spray on your varnish?
Video of Midnight in Action
Blog
PostPosted: Thu Jul 19, 2012 3:48 pm
hi kens- could you snap a pic of the trailer if you get a chance. what frames do each set of bunks sit on?
Dave- I just spraying with a Porter Cable gravity HVLP gun. Nothing fancy. Done a LOT of spraying with it. This will be my first time, however, with varnish.
Should need be, my back-up will be a Graco HVLP turbine unit. Haven't used that one in a while. It puts a fair amount of heat through the large air hose, which for varnish, shouldn't be too bad. But it lays down a nice layer of product. I'll keep all informed.
PostPosted: Thu Jul 19, 2012 5:05 pm
I have that Graco turbine unit. I used it on water based poly full strength and was quite impressed. I have not tried the varnish thru it though. Should be an interesting exercise. Let me know
Blog
PostPosted: Thu Jul 19, 2012 5:57 pm
I got my trailer from ACE Trailers out of Florida. Mine looks like all the others on his website. Here is a link to one;
http://www.acetrailers.com/phpAlbum/mai ... ar2=700_85
My boat is here, you can see my trailer in some pics:
http://www.glen-l.com/picboards/picboard9/pic503a.html
PostPosted: Thu Jul 19, 2012 6:08 pm
trisailer
I have double bunks also. They seem to give good support. The only problem I have is that the closest the rear bunks can be spaced is 4 feet. The Tahoe's transom is only about 5 feet. It is difficult to center.
PostPosted: Mon Jul 23, 2012 10:27 pm
moved the boat off the building bunks onto the trailer (or at least the frame and one set of bunks) looks a lot different sitting on that trailer.
File comment: trailer, stripped to the frame, with newly constructed dolly wheels
File comment: trailer frames are big and heavy for one man to move. balance and slide
File comment: hoisting it off the building cradle
PostPosted: Mon Jul 23, 2012 10:32 pm
OK, it's on the trailer, time to move it around 180 degrees in the shop, so the boat comes out bow first
File comment: trailer's underneath!
File comment: almost half way
File comment: turned around
PostPosted: Mon Jul 23, 2012 10:37 pm
the finishing continues
File comment: I think it's time for the old epoxy cans to go
File comment: finished wiring the dash and fuse panel (minus 3 pcs of 10ga wire)
File comment: sanding on the 5th coat
PostPosted: Mon Jul 23, 2012 11:01 pm
Getting there now, she's looking good I look forward to see the engine going in and hearing her rumble :D
