Riviera frame 3
Old aussie
Riviera frame 3
Post by Old aussie » Tue Feb 07, 2012 5:28 pm
Old Aussie
Riviera frame 3 the plans show frame 3 may have to be trimmed to allow the motor to fit, I am thinking of doing
that before fitting the frame , motor will be 350 chev type . if i trim the floor ply inside the stringers down to the
timber frame would that be enough, I thought it would be easier to do now than later on in the boat.
the build is going well i should be fitting chines,sheers battons in a couple of days, i will post pics when i work out
how to drive this computer,
Peter
Re: Riviera frame 3
Post by Bill Edmundson » Tue Feb 07, 2012 5:38 pm
Dave Lott
Where are you? Getting food for the Gathering?
DaveLott
Re: Riviera frame 3
Post by DaveLott » Tue Feb 07, 2012 9:24 pm
HERE HERE.
Ok, yes you will have to trim Frame 3 just above the keel so that your oil pan will clear. The engine compartment is tight - very tight for our modern engines. If you are using a carbed engine you will probably have to provide some modification to the hatch to clear the air intake. Some EFI engines fit barely. Mine has less than .5" under the pan and NO clearance on the spark arrestor.
I would not trim the frame now. Is is not difficult to trim what needs to be done later. You will want this frame to be a solid as possible as you build your hull. Once the hull is done, then the frame can be trimmed. Also, you will not really know what you need to cut until you lower the engine and mark the frame accordingly.
dave
Glen-L Sea Kayak
Mahalo Standup Paddleboard
Video of Midnight in Action
DaveLott
Re: Riviera frame 3
Post by DaveLott » Tue Feb 07, 2012 9:25 pm
Bill Edmundson wrote:Dave Lott
Man church!!!! First Tuesday of the month. Great time
Glen-L Sea Kayak
pamelalynne1
Re: Riviera frame 3
Post by pamelalynne1 » Wed Feb 08, 2012 1:20 am
That sounds like an old fashioned fellowship dinner. Please pass the rolls, Dave.
Old aussie
Re: Riviera frame 3
Post by Old aussie » Wed Feb 08, 2012 3:14 am
Old Aussie pics
jprice
Re: Riviera frame 3
Post by jprice » Wed Feb 08, 2012 7:02 am
Nice work.
Man, every time I see a big shop like that, I get jealous.
That's a pretty sweet backyard you have there too! :D
DaveLott
Re: Riviera frame 3
Post by DaveLott » Wed Feb 08, 2012 7:40 am
pamelalynne1 wrote:That sounds like an old fashioned fellowship dinner. Please pass the rolls, Dave.
Actually that was the "beast feast" a couple of weeks ago. The men of our church actually hold a service specifically to address the needs of men> Last night we dealt with the stress of the workplace. All is good.
Glen-L Sea Kayak
Old aussie
Re: Riviera frame 3
Post by Old aussie » Sat Feb 11, 2012 12:03 am
Old Aussie Riviera build
No message with photo of Riviera frames still learning to use computer I am getting there,
as you could see my build frame is made of steel, I have designed it so I can jack the whole thing up 500 mm so it is
easier for me to work on without bending over ,back injury, I have also built a rotisserie i will be able to turn it on its
side and roll it right over when hull is finished.
I will try to send pics of jigs i made up to hold battons while glue sets, and pre bending battons chines shears,
thanks Dave for the advice,
Peter
Old aussie
Re: Riviera frame 3
Post by Old aussie » Sat Feb 11, 2012 12:09 am
Old Aussie
Got one on will try again,
upspirate
Re: Riviera frame 3
Post by upspirate » Sat Feb 11, 2012 4:39 am
Old aussie, you are doing great....you can add more pics,up to three per post
