Lakeracers Crackerbox build
J Patroni
Re: Lakeracers Crackerbox build
Postby J Patroni » Sat Oct 27, 2012 10:12 pm
lakeracer69 wrote:A couple of pictures. Building form and frame mock-up, and engine 350 Chevy with Brodix heads and Lunati roller cam.
Lakeracer,
Did you use plywood for your frame mockups?
If you don't build it now, You will regret it later! Already regreting it
Crackerbox Build
Checkmate Restoration
http://s232.photobucket.com/albums/ee25 ... 0Starflite
lakeracer69
Postby lakeracer69 » Sun Oct 28, 2012 6:04 am
The frames are completed. 3/4" Doug Fir with 1/4" plywood on both sides instead of gussets.
A small weight penalty, but I have 400+ hp to push it. 8)
lakeracer69
Postby lakeracer69 » Sat Jul 13, 2013 5:48 pm
Got a little further on. Fairing done on chines and first layer of bottom planking fitted. I need to get some white oak for the sheers. Doug fir even steamed would not take the bend at the back by the transom ( 4 laminations ).
For those that have done a double planked bottom how did you attack the first layer to the chines, battens, keel, etc. ? Did you screw and glue everything down and then remove the screws to screw and glue down the second layer or some other method?
Mr Hot Rod
Postby Mr Hot Rod » Sat Jul 13, 2013 8:30 pm
Great progress on the boat !
    On the first layer, we pulled the temporary screws after the epoxy had cured. We also recessed the chine to accept the first bottom layer.
    Fitting the port second bottom. We used steel screws with the same thread pitch as the silicon bronze screws.
    Once all the screws were driven in, they were removed one by one and replaced with silcon bronze screws.
Click here for more details.
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
lakeracer69
Postby lakeracer69 » Sat Jul 13, 2013 8:43 pm
Thanks Mr. Hot Rod,
That is similar to what I envisioned. : )
What type of steel screws did you specifically use that had the same thread pitch?
I already have a pile of those small plywood squares already. LOL
fergal butler
Postby fergal butler » Mon Jul 15, 2013 3:51 pm
Your getting there now keep up the good work. When you are doing the side planking make sure you use the best bit of ply near the transom, check it for any voids or knots or anything that might give way under severe strain. "I learn from my mistakes " :D
lakeracer69
Postby lakeracer69 » Fri Jun 23, 2017 7:35 pm
I haven't posted in a while. All ready to put on the bottom layers.
lakeracer69
Postby lakeracer69 » Fri Jun 23, 2017 7:37 pm
another picture.
