Building The Vera Cruise
Re: Building The Vera Cruise
Post by chugalug »
having to use little wranglers room at critical times is a pita.I have a coffee can with wood pellets in it when I'm in the boat.no smell ,even after a few days.just have to put it where I won't trip over it(like in my phone booth toilet area) :D
The first step in mixing epoxy is to go to the bathroom first. :lol:
Post by Jimbob »
Hey Carl,
Check out the 1st boat in the link below.
https://laketahoeconcours.com/
No you mix the epoxy, nervously spread it, then run to the bathroom while the unfinished part solidifies. :lol: :lol: :lol:
Post by Jimbob »
I never mix and apply epoxy unless my urinary catheter is in place first. :lol:
jim
Roberta wrote:
Thu Aug 01, 2019 12:56 pm
Yep, this is what I did! :D :D
Jim, I assume you meant the sedan cruiser in the photo. It does look great. Although mine won't be a sedan cruiser, I have considered it a few times in the past. The main reason I didn't was because of the tremendous heat here and I wanted to leave the V berth available for full length sleeping.
The temps have been very high here these last few days and I have had to help my son move. I finally got back to the boat yesterday and completed the third roof beam. One more to go this Saturday morning. I am also going to be cutting out the first piece of the fore deck and start the fitting process on that. Laying the beams across the top of the cabin sides and having the cardboard template on the fore deck is making the boat look a lot more real now. The pile of parts waiting in my storage closet is just waiting for me to get to a point where I can start putting them in. Everyone keeps asking when am I going to finish. It's been nearly 7 years and I want to be further along. Glad the journey part of this experience is so satisfying.
Post by chugalug »
:D I can't wait until you're in my situation-buying all the necessary items to finish.it's the law in minnesota,if one has a sleeping area or enclosed cabin,to have co2 detector and fume detector.Wow those are spendy.I'm gonna need a bigger boat to haul it all. :D
chugalug wrote:
Fri Aug 02, 2019 5:40 am
:D I can't wait until you're in my situation-buying all the necessary items to finish.it's the law in Minnesota one has a sleeping area or enclosed cabin,to have co2 detector and fume detector.Wow those are spendy. I'm gonna need a bigger boat to haul it all. :D
A lot of the major parts have been purchased over the years and are waiting in the wings. Still some big ones to go. Most of the small connecting stuff has not been purchased. You know, important things like clamps for fuel lines and latches for cabinet doors!! :D :D
The good thing is that I have enough for the motor now so that's a load off my mind. Trailer funds are close to there. Next big purchase will be instruments and controls as well as electrical(mostly wire as well as batteries and such). A lot of this stuff will wait until later since I am running out of room to store stuff and some items I want to wait until getting closer to actually needing them (like the batteries).
Another hot weekend and some more work accomplished. I am now done making the four roof beams. All that remains is to fit them to the cabin sides at some future point. But there is other work to accomplish first, staring with the decking. I started fairing the fore deck area. This is the only area remaining on the top side that has not been faired. However I made good progress on that today.
Here are a few in progress shots.
Using a rough cut out of the port deck to check where faring is needed.
Still have a little more fairing work to do here.
Denon Osterman
Post by Denon Osterman »
Hey Carl,
Lots of progress - looking great! Will you be finishing the entire roof bright or just the cross beams?
I also love my Evinrude engine - can't recommend it enough.
I didn't realize how luck I was that "the great outdoors" was literally 5 feet from the boat, which was built in a shed in the woods far from prying eyes...so I've never had to worry about when I mix my epoxy ;)
I will say that all of the little odds and ends...fuel hose clamps, wiring, screws and nuts and washers for deck hardware, etc...they all really add up, and I keep forgetting them! I didn't forget the engine, but I'm terrified I'll have everything ready to go...and won't have ordered spark plugs or something. Sigh. Same thing with the boat...I'll put the whole thing in the water and realize I don't have any bolts to attach the steering wheel or something!
Thanks Denon,
The cabin sides will be bright finished. The roof will painted white on the exterior. Haven't decided yet how the interior will be finished, but I plan on a few electrical wires in that area so there may be paneling or I may try to hide it in the framing somehow. As this is not critical to getting the boat in the water, it will likely be quite some time before I get to that.
Denon Osterman
Hi Carl,
That all makes sense. Hiding the wiring might make you regret doing so years from now - paneling would be my choice. If you painted the inside (hopefully at least keeping the cross members "bright"), would you paint the wiring as well, or still try to hide it?
Cheers,
-Denon
Paneling is my current choice. Wiring would be hind the paneling. If hidden in the structure, It would probably be something like a removable piece (cover) that blended into the wood. I'd like to keep the beams bright finished and showing. Paneling will most likely be painted, but who knows for sure. I have to figure out something for the interior of the deck above the V Berth as well.
It's been a slow week for me. Back problems have made it difficult to work on the boat. Started feeling somewhat better yesterday so decided to give it a go. I am concentrating on getting the foredeck structure faired and the deck skins fitted. This will be a great milestone when completed, giving the boat a much more finished look. Something I've been looking forward to for a long time.
I admit however, that I had some trepidation about the very bow fairing with the strong back. I was sure this was going to be difficult to accomplish. However, it has turned out to be easier than I thought. I recently purchase a smaller hand plane and this has helped a lot. Cutting the full size skins out (roughly for now) has also been a big help since I can clamp it down and see where work still needs to be accomplished.
At this point I am nearly done with the fairing with just a little more clean up to accomplish. I'll be cutting out the second skin as well today. There's some work to be done, before attaching the decks, determining locations of deck fittings, encapsulating the structure under the decks, and just handling any loose ends that are easier to do with the deck off.
The anchor well is going to be covered over for now, however, the structure for the hatches to access this area will be added before the skins go on. Then at some future point I will cut out the openings for the hatches and add hatches to the deck. The same will happen with the center deck hatch which will be added later.
In the photos, the deck skins have only been placed on the boat and are held in place with clamps and cinder blocks.
The faired structure under the fore deck. This is nearly ready to go with just a bit more clean up needed.
View from inside the anchor well. Obviously, the anchor well needs some cleaning up as well.
A view from inside the V berth.
Milhouse
Post by Milhouse »
Looking great Carl!
I feel like a large part of building these boats is getting ready to jump into the next stage and getting started on it. Once the leap is made one can really make nice progress like you have done.
16' Ski Boat Restoration
17' Overnighter Sloop
