modified malahini
Re: modified malahini
Post by DrBryanJ »
Next problem: Started to fiberglass bottom. Used System three epoxy on starboard side. No problems, but I ran out. Used Silvertip on port side. Applied 12 hours ago. It does not seem to be setting. Mixed at a 100:44 weight ratio as stated on bottles. Mixed for 2 minutes. What should I do? I'm inclined to removed port side fiberglass, clean up mess and start over with System three. Also, I don't want to start filling the starboard side with SilverTip as it may not set and cause I bigger mess. Can I let starboard side fully cure and fill cloth later?
Bryan,
Two things I would do here.
First, wait at least a day (assuming it gets up over 50 degrees today) to see if the epoxy is just slow curing because of the cold.
Secondly, in a controlled environment (i.e. not cold) test out the Silvertip on a scrap piece of wood and glass to see if you have a bad batch.
In cold weather I often put a small space heater under the hull.
Post by Jimbob »
Hi Bryan,
I would wait also. I also use the silver tip epoxy myself. Even in warm weather it usually takes overnight to cure using the slow hardner. I have worried in the past, but it always cures. Cold weather really slows things down. I have been putting the epoxy containers in warm water in my utility sink before I mix them up. As bill said, try a space heater. In cold weather I use the fast hardner, and in hot weather I use the slow hardner.
12 hours is not really long enough. I haven't used Silver Tip much. I generally use the System Three General Purpose, but you do need to recoat in 24 hrs or clean and sand to remove any blush and rough up the surface for a mechanical bond.
Post by DrBryanJ »
Well, I figured out the stupid mistake I made.
I don't want to admit what I did, but I guess I will so others don't make the same mistake. :oops: :oops: :oops: :oops: :oops: :oops: :oops:
When I grabbed my new bottles of epoxy I grabbed 2 bottles of part a. I read the label on one bottle, so of course, the other had to be part b. I happily applied the fiberglass cloth and couldn't figure out why it wasn't cured in the morning. It finally dawned on me the two bottles should be different sized. So, now I have removed the bad cloth and cleaned everything with acetone and warm soap and water. When my new cloth arrives I will try again. After hunting through the basement I finally found the other two bottles of part b. I am now filling the weave on the starboard side.
Oooops!
Post by PeterG »
There you go! Nice recovery... A lesson for all of us to learn from :D
I think you should have given it another day, to see if would set up! :D
The nice thing about silver tip, is the no blush qualities. You have 3 days to recoat without sanding, but if you are applying multiple coats you have to make sure you have a plan to get the subsequent coats applies within that 3 day window.
Post by DrBryanJ »
JimmY it never would have set. I mixed part A with Part A, not part B. Stupid trick, but one I will never do again.
Post by DrBryanJ »
So, I have the fiberglass cloth on. I have put on an additional 2 coats of epoxy (three total). I can still see the texture of the cloth. Do I need to continue filling the weave, or should there be enough epoxy to sand and make everything smooth?
That’s probably enough. You might have to fill in some low spots with more epoxy. As you sand you’ll get a feel for when you’re about to sand into the cloth. My next step was building the transom edge back up and sanding it to a sharp corner.
Getting close to a flip on this one.
Post by DrBryanJ »
Thanks Matt. Yes can finally see some hope of flipping. Only have sand, prime, paint, add lift strakes and spray rails, and build cradle before flip. At my pace it will only take me 1 year. I laugh when I think how at last two gatherings I said I'd be flipping by Thanksgiving
I usually do 3 total. If you're painting, it doesn't matter if you just start to see cloth. With bright work, put another coat on at the slightest sign.
Post by DrBryanJ »
Thanks Bill. I guess it's time to sand again.
