modified malahini
Re: modified malahini
Don't plan on reusing the mix container as that stuff gets really sticky and hard to get out of containers when cured.Not sure what happens in colder temps but foam in a can won't set up too much.Don't glue yourself together if you get it on your clothing
Thanks for the advise Chug. I plan on using 20oz paper cups for mixing and pouring that I can just discard when done. Apparently this stuff likes temps above 75. Even my kitchen isn't warm enough. Either I wait until summer or turn the heat up.
don't overfill in enclosed spaces.will pop your boards loose.Might have to up heat.They say you save money by building your own boat.I Fibreglassed my boat in January so went thru 3 semi loads of wood for heating in boiler.At 1400.bucks a pop-wheres the savings?Sure is fun tho.
