My Ski King Build
FreshGrooves
My Ski King Build
Post by FreshGrooves »
Hi Guys,
Im building the Ski King since dec. 2010 and have posted now and then some pictures of the progress. Here are some new pictures!
I cutted frame no. 5  to fit my engine. The missing piece wil be replaced after fitting the engine.
I have flipped the boat many times already and got tired of the challenging proces, so I made a mould for the final
I glassed the bottom wit 200 gr glasfiber, the sides with 60 grams.
FreshGrooves
Re: My Ski King Build
And where I stand now...
I think I will coat the 5 missing layers on the sides when I instal my deck, maybe that wil give a nice transition?
Painted the bottom with 4 layers primer and 1 coat in ´off white´  the side wil be varnished with 6 coats of De IJssel double coat UV  coat, famous here in holland because of the quality. Still need to coat 5 more layers...
fergal butler
Post by fergal butler »
Very nice I love the colours in the wood, the turn over setup looks great too and saves on buying beer for a gang of lads :D
Post by vupilot »
Fantastic!!!!! what paint did you use?
FreshGrooves
thanks! All the paint I used is from the dutch company ´De IJssel Coatings´(http://www.de-ijssel-coatings.nl/english/home.html)
Bottom: 4 layers 2 comp. primer, called IJmopox, then one layer double coat, also 2 components.
Sides: 1 one layer ´Double Coat UV, Two component polyurethane varnish. High gloss. Easy to apply by brush or roller. Scratch resistant. Excellent gloss and colour retention, non yellowing. Suitable as transparant finish for most types of wood.
Colour: transparant.
Packaging: 750 ml set (base with hardener)
AMPlas
Post by AMPlas »
Hi
see you have cut out the top center section of frame 3. What is the idea behind this?
regards
FreshGrooves
Hi AMPlas,
My engine is too big! When I have installed my engine I will put the cut frame member back!
Nice!!! Can't wait to see it in the water!!
Roberta :D :D :D :D :D
potnol
Post by potnol »
Hey,
Ik ben van Hasselt (België).... mooie boot veel werkuren erin zitten ?
Keep up the good job :!:
Grtz
FreshGrooves
Hey Potnol,
Dank voor je bericht! Ik ben er nu ongeveer 2 jaar mee bezig (met lange tussenpozen ivm werk)
Groeten
(Translation: Potnol asked how many working hours are in this project, my answer: 2 years of building (with large gaps between because of work)
Moeregaard
Post by Moeregaard »
Your build is looking really good. What engine and transmission will you be using?
-Mark Shipley
FreshGrooves
Engine: Mercruiser 3.0 TKS and the transmission is a Twindisc/Technodrive Down Angle (down angle so that I can fit my engine more horizontal)
FreshGrooves
UPDATE!!
I finally started at the installation of the motor, it´s aligned know (I think I was very lucky on my initial set up,the whole aligning proces took me about 45 minutes) I was very scary since the start of the build for the aligning so I am happy the way it went.
The exhaust system is also ready and the cooling system almost.
FreshGrooves
And more pictures:
Moeregaard
Very nice job! Your engine installation is very neat and clean!
-Mark Shipley
