batteries in the bilge area
TOM K
Post by TOM K »
was planing on putting my batteries below my deck in the bilge area. all the boat I have had in the past they sat on the deck at the transom. they will be just forward of the engine and the compartment will be ventilated. JUST DONT WANT YO BLOW MYSELF UP :)
bob smith
Re: batteries in the bilge area
Post by bob smith »
Check out the post "Not if but when"
Bob Smith
Chester, SC
TOM K
Post by TOM K »
Yes I already did. If I put a bulkhead in it might cut down on air circulation :?: , would one of those plastic battery boxes contain a explosion ?
mud
Post by mud »
fit solid state batteries, plenty of choices available, they will also handle the pounding of a boat better than normal batteries , and fit them as low down and to the rear of the boat as possible , ----Mud ,- South Oz
mk e
Post by mk e »
Hydrogen (from the battery or anything else) is much much lighter than air so it shouldn't collect in the bilge like fuel vapors will so I don't thing I'd be too concerned about the mounting location???
graham mackay
Post by graham mackay »
Hi Mud
Could you expand on the concept of solid-state batteries please? I'm thinking of general size, cost, safety, availability etc. versue conventional lead-acid.
Graham
I am presently constructing a Glen-L HERCULES, hull basically complete.Am going to fiberglass and paint bottom and then turn over. Sides to be planked with10mm yellow cedar edged bead and cove . Engine is Mitsubihi 4-cyl. 39 crankshaft hp.
