spray rails.rub rails.
svenole
Re: spray rails.rub rails.
Post by svenole »
2 man job
svenole
Post by svenole »
Have not done this yet >doing other things> Screw from inside or outside? I am using 2 half in. pieces for the curve on the hull. there going on with epoxy >im not worried about the nicks n scratches>>what is the best way to screw them on?
svenole
Post by svenole »
Post by billy c »
screw rail into each frame. where that isn't possible, thru bolt and reinforce. caulk holes and rail with 4200 or similar
-Billy
svenole
Post by svenole »
I mean to laminate the 2 pieces.so im going to glue n screw the first one with a small screw that wont go all the way though>then screw n glue the second one on top With small screws then when there on ill bolt though. done >white oak
Tim Major
Post by Tim Major »
svenole wrote:Waa :?:
Very amusing......oh, and good luck with your spray rails. Good advise I think to caulk/Sika per Seiner recommendation
svenole
Post by svenole »
IT says on my PLANs not to screw them into my frames . Not sure why so I didn't but it would have been much easier. Do you know why?
svenole
Post by svenole »
There so low I cant see it affecting anything in the way of the hull flexing?! I can see the hull flexing higher or even the middle but not at 12 inchs from the bottom.
svenole
Post by svenole »
Spray rails
svenole
Post by svenole »
svenole
Post by svenole »
:?: :!: why cant u screw them into the frames. :?: :?:
I screw them into frames. Never had a problem. Well, on second thought I didn't. I already had the shear and chine logs screwed to the frames in those locations.
svenole
Post by svenole »
How could that be?
BayouBengal
Post by BayouBengal »
Why can't you epoxy them, or glue them with 5200?
svenole
Post by svenole »
The spray rails are not close to the chines and the sheers :!:
