Garboard drain plugs
Post by neel thompson »
I never put drain plugs in my Gentry, and now would like to do so. I am wondering if anyone has put these in through the bottom of the boat near the transom. I would put one on each side of the keel about 5" in from the transom. the square plug would be on the outside of the boat. Would this cause a problem with performance? Looking for advice.....Thanks,,, Neel
Re: Garboard drain plugs
Post by billy c »
at this point you might think about garboard drain plugs in the lowest point of the bilge instead.
trisailor
Post by trisailor »
If you are concerned about the square plug sticking out and interrupting the water flow, you might consider a flush head instead.
as to Billy's concern of mid-ship location. a valid concern, indeed, but a little tougher to get at, while on the trailer. I think easily solved if you just use the trailer jack to raise the front until all the water runs fully aft and out near the transom.
I hit a BIG wake yesterday and took maybe 5 or 6 gallons over the bow and into the engine compartment (I had the main hatch off for some carb adjustments). my aft mounted bilge pumps got almost all of the water out immediately as all the water flowed all the way back while underway. when I got home there was still about a cup of water midships in the bilge. I just cranked up the jack a bit to move the water to the cockpit area, where I popped out my egg-crate floorboards a soaked up the remainder with a towel.
quite easy. I think I'm going to stick with no drain plugs for a while.
TUGMYWAY
Post by TUGMYWAY »
Can you say wet-and-dry Vac? :lol:
I put the flange on the inside and ground the neck to be flesh with the hull. They're NPT threads and the plug stands proud.
I don't have the on the Tahoe. I do use the W/D Vac. But, it's another step at take-out and you have check every time the boat is out in the rain.
TUGMYWAY
Post by TUGMYWAY »
MY God! Bill? Out in the rain! :shock:
In AZ we go out to see it rain. :wink:
Tug
That is what a friend of mine said after she moved to Tucson. When it finally did rain she just went out to stand in it!
TUGMYWAY
Post by TUGMYWAY »
Good times, Bill! Good times! :mrgreen:
Randy
