Making wood patterns to cut out parts?
TUGMYWAY
Post by TUGMYWAY »
Would you go from the paper patterns to the wood or take the extra step to make patterns out of 1/4" wood then transfer to the wood part?
Randy
fergal butler
Re: Making wood patterns to cut out parts?
Post by fergal butler »
I went paper to wood just putting a pin prick along the line then joining the dots I then cut just outside the line and sanded down to it. You will have enough wood to be cutting without making more work for yourself :D unless you plan on making more than one of the same boat then a template would be handy :lol:
Randy
You can get a roll of stiff cardboard at HD which makes nice patterns. I forget how long in is 25' to 30' x 38". About $25 as I remember. It also makes a good drip cover on the floor.
TUGMYWAY
Post by TUGMYWAY »
Great idea Neel. :o I have some of the painters cardboard. Its like 1/16" x4'x3'. It looks just about right! Thanks.
fergal butler,I have that photo in my build files. :lol: Thanks
Randy
Bill Edmundson wrote:You can get a roll of stiff cardboard at HD which makes nice patterns. I forget how long in is 25' to 30' x 38". About $25 as I remember. It also makes a good drip cover on the floor.
Bill, do you happen to know a part number or a product name for this. I am interested in finding a source of cardboard sheeting and this sounds like it might fit those needs. I tried searching Home Depot but had no luck
TUGMYWAY
Post by TUGMYWAY »
Carl,here is a photo of the stuff I have. Its called Tank board,sku 192791 Its not the stuf Neel is talking about I don't think?
Randy
TUGMYWAY
Post by TUGMYWAY »
My BAD ! :oops: Bill !
Randy :roll:
Thanks for the link Bill.
So a quick question. Would that material be suitable for mocking up cabin interior pieces or is it too flimsy for that?
Probably too thin for that.
rbrandenstein
Post by rbrandenstein »
I used white posterboard to make patterns. I edge taped (both sides) pieces together to make larger pieces when needed.
Worked well for a one time build. Remember that the outside of all frames need to be faired to final shape, so being 100% accurate to the prints is not required.
________________
trisailor
Post by trisailor »
I used 1/8" tempered masonite. Worked well.
BayouBengal
Post by BayouBengal »
I use scrap 1/4" or 3/8" plywood to make frame templates, then temporarily screw the templates onto the framing wood and use a flush cut router to cut the frames.
Mr Hot Rod
Post by Mr Hot Rod »
We might be building more than one boat, so we made plywood templates for the frames and other boat parts. This will save a ton of layout work if we ever build another one !
  • Image
    Frame parts ready to be trimmed.
    Assembly board, frame templates and plywood lamination templates.
Click here for more details.
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Bill CNC
Post by Bill CNC »
I just went to my friendly copy center and had a copy of the plans made. I kept the original plans for reference and I cut the copy plans up and used 3M-77 spray adhesive to lightly apply the plan piece to the wood I then cut and sand to the paper. Just a very light misting on the paper is all that is needed.
Perfect parts, ... FAST and SIMPLE!
