Matt's Geronimo
Re: Matt's Geronimo
Tom, great minds think alike. Now you can put your snack on top and it won't slide off so easily.
Re: Matt's Geronimo
Here we go. Just gotta take everything back apart, sand, and polyurethane. I've also used every bit of wire that I had hooking everything up. It's amazing how much wiring there is in a boat this size.
Re: Matt's Geronimo
Post by chugalug »
when I bought marine wire,I got spools of the different sizes(some I haven't used yet)Might have build another boat to use it all :lol: it's challenging trying to route it all so it doesn't show.
Re: Matt's Geronimo
Nice upgrade,
Re: Matt's Geronimo
Nice work Matt.
Re: Matt's Geronimo
I'm going to try a four-blade prop. Mainly hoping to eliminate cavitation in tight turns. The new prop rings like a bell, which seems indicative of the casting quality.
Re: Matt's Geronimo
Let us know how it performs. I have to be trimmed all the way in for a tight turn on plane or prop sucks air.
Re: Matt's Geronimo
Hercdrvr wrote:
Wed Jun 17, 2020 7:13 pm
Same here. I'm going for a test run tomorrow.
denbrlr
Re: Matt's Geronimo
Post by denbrlr »
I hope the new prop works well. Splash away :)
Lee
Re: Matt's Geronimo
The new prop seems to be a winner. The boat is way easier to control in just about every way. I don't have to be trimmed all the way down for turns. The cavitation problems are pretty much gone now. It is a Turning Point Hustler 13x17. I am thinking I will trade it in for a 13x19 as I am hitting about 5800 RPMs at WOT and I lost a couple of MPH at the top end. I think I'll get some back going to the 19 as that is the pitch of my old prop. Turning Point recommends not changing pitch but I did anyway.
Matt, this might eliminate the need for those trim tabs. I have way more control trim wise.
Re: Matt's Geronimo
Glad you’re pleased with the prop. I’m running a 13.25 diameter x 15 pitch, 3 blade stainless. 5400 rpm is the top with a light boat. I just don’t think my 3 cylinder 90 has the grunt that your 4 cylinder does.
Most importantly, you were on the water in a boat you built from a few pieces of paper that came rolled up in a tube.
Re: Matt's Geronimo
Mine is a 3 cylinder as well. Evinrude says 5000-5500 full throttle range. So I probably shouldn't be winging it up to 5800. I'll go up a size.
It was a fun cruise on the lake. A lot of people waving and asking questions at the ramp. I also got a chance to really break in the new speakers.
Re: Matt's Geronimo
I didn’t know Etec 90 hp are a 3 cylinder, cool.
Re: Matt's Geronimo
There is a 90 H.O. that is a 4 cylinder. It is a detuned 115. There is a 70 lb weight penalty.
footer
Re: Matt's Geronimo
Post by footer »
I went from a 3 blade to a 4 blade power prop on mine and it improved my hole shot. I don’t have any problem with cavitation, but I have my motor set just a bit lower.
