Matt's Geronimo
Re: Matt's Geronimo
Great news about the prop Matt. Glad it worked out.
Re: Matt's Geronimo
We spent three days camping at Raccoon Lake last week. We were able to put the four-blade Turning Point Hustler prop through its paces. I traded the 17 pitch in for a 19 pitch. We were loaded down with four adults, a five-year-old, a full cooler, and a full tank of gas. Was able to hit a little over 37 mph. Although there wasn't much smooth water to really wring it out.
Much better steering. If it does happen to suck air it recovers much quicker. Turns are much sharper and the boat will really lean over in the turns vs. staying kinda flat with the old prop.
Much better trim control. With the engine trimmed down the bow is pointed lower than the three-blade making the ride much smoother in rough water. No high speed proposing unless I try to trim it out. Didn't get to try a run with a lighter load but I suspect I would be able to trim it up and be within 1 or 2 MPH of the top speed of the three-blade.
I'd suggest that if you are thinking you might need trim tabs on your outboard boat maybe try one of these aluminum four-blade props. For about $100 bucks with a new hub, it's cheaper and easier to try than the tabs. If it doesn't work most places will take them back no problem (as long as you don't scratch it.)
Re: Matt's Geronimo
Also, I had a little problem with the swim ladder. This was the on-the-water solution to get everybody back aboard.
Milhouse
Re: Matt's Geronimo
Post by Milhouse »
Sounds like a fun trip Matt! Glad you are out there using your boat
16' Ski Boat Restoration
17' Overnighter Sloop
denbrlr
Re: Matt's Geronimo
Post by denbrlr »
That does sound like fun. It is really satisfying to ride in a boat you built :)
Lee
Re: Matt's Geronimo
Post by vupilot »
I flew over Raccoon lake Saturday about lunch time, couldnt believe how many boats were out there!
Re: Matt's Geronimo
Sounds like it was a blast Matt. I was just telling my wife to remember all the days I was out in this heat sanding and doing other nasty stuff when we finally get ours out on a lake.
footer
Re: Matt's Geronimo
Post by footer »
Smart thinking on the ladder there, McGuiver. 😀👍
Glad your having so much good luck with the prop. I did try the 4 blade first, but it didn’t help me with the porpoising. It did give me a better hole shot. What really helped me Were the trim tabs. All my weight is in the stern, and when I had 4 people in the boat, it took me 15 seconds to get on plane with a lot of bow rise. Now with the trim tabs, I’m there in 5 sec easy with very little bow rise (which I absolutely love).
I do get a center spray from them that hits the tuber. I played back and fourth with the adjustment (it’s pretty easy) and found a happy medium.
I think I paid $110 for the pair.
Re: Matt's Geronimo
I came up with a fix for the ladder. The original design for the ladder is not great with just two tiny screws trying to hold the weight of a grown ass man. I bought a piece of aluminum and made some gussets. Since I have no way of welding aluminum I used rivets. It is now way more solid than it ever was.
Milhouse
Re: Matt's Geronimo
Post by Milhouse »
Great fix, looks like it was meant to be there!
Re: Matt's Geronimo
Perfect!
Re: Matt's Geronimo
Nice straightforward fix Matt. Why companies make these things so cheap is really a shame.
Re: Matt's Geronimo
I have both halves of the windshield glued together. Somehow, I think this is actually going to work.
Re: Matt's Geronimo
There are lots of angles and arcs at play In your windshield, not an easy task. Stay with it.
acflynn
Re: Matt's Geronimo
Post by acflynn »
Wow - very impressive! I'll be watching your progress on this closely. The Mist Miss has a wood windshield prescribed as well, and I have some ideas on that. Best of luck on this part
- Andrew
