Cabrons Zip Build
BayouBengal
Re: Cabrons Zip Build
Post by BayouBengal »
The vintage motors are cool, but there's a lot to be said about modern technology. Too pretty a boat to not have in the water due to motor problems. Nice motor. Have fun this summer!
joshuab
Post by joshuab »
So cool! I knew you were planning on swapping to a four stroke, keep me posted.
Cool Josh,
I'm torn between keeping costs down wit an older motor and biting the bullet for a new Etec 115.
Cabron
Post by Cabron »
Hi Carl,
Of course you will be more than pleased with a new motor. If it`s in the budget...go for it.
After all the work you are putting into the boat build, It only makes sence to put a new motor
on it. I`m sure you want to get the most performance out of it as do I with my ZIP.
Make sure you get the power trim.
Josh
scottp
Post by scottp »
I just wanted to draw attention to another amazing collection of construction photos ( over 400) for the ZIP
boat by bjfrater
https://plus.google.com/photos/11224084 ... PTuxIG26AE
I know there are several other outstanding photo collections of the ZIP build and that interests me because
I want to build the Tiny-Might which I believe is very similar only inboard powered instead of outboard.
bjfrater
Post by bjfrater »
Thanks for the reference Scott.
Im around on this forum as well.
Brendon.
Cabron wrote:Hi Carl,
After all the work you are putting into the boat build, It only makes sense to put a new motor
Make sure you get the power trim. Josh
I will have to wait until I get closer and see how it goes. I will definitely be getting power trim on whatever I end up with.
