Roberta's Torpedo
bob smith
Re: Roberta's Torpedo
Postby bob smith » Tue Oct 11, 2016 10:08 am
Regarding the tabs, did you experience porposing? Mine in its original state would porpose and I had installed Bennet trim planes to correct it.
The new configuration moved the CG forward about 5", added an inch to the beam and removed about 250 lb from the BBC (aluminum heads, intake, exhaust, water pump). Now there is no hint of porposing and she rides noticeably better than before.
If you haven't played around with weight distribution/CG, I'd try before adding the tabs.
Bob Smith
Chester, SC
Postby Roberta » Tue Oct 11, 2016 10:30 am
It would need more weight in the front to bring the bow down. I really don't want to do that as it already sits low in the bow at no wake speeds. Up to 40 mph it rides fine, but above that It wants to climb out of the water. The tabs will bring her down without get to far forward with the CG. Thanks for the comments, though.
Roberta :D :D :D
bob smith
Postby bob smith » Tue Oct 11, 2016 12:33 pm
I forget, did you lengthen the build?
Bob Smith
Chester, SC
Dave Grason
Postby Dave Grason » Tue Oct 11, 2016 1:20 pm
Can you even respace the frames for additional length? I would have figured that the torpedo harpin would give problems if someone wanted to do that.
On the OTHER hand, the original Ventnor boats that put this style on the map were often double cockpits. I'd be willing to be that they pushed the dashboard and front windshield a little forward and simply moved the back of the rear seat just a little aft. Hmmm. They could probably squeeze out just enough that way.
Ok, I'm sorry. You folks were talking about CB and CG. My bad. :roll:
Postby Roberta » Tue Oct 11, 2016 2:33 pm
Yeah, Really Dave!!! :lol: :lol: The Harpin makes lengthening difficult, if not impossible without a redesign. At 19' 3", it's long enough for me.
Roberta :D :D :D
Postby kens » Tue Oct 11, 2016 3:33 pm
Why trim tabs??
I noticed you currently have a heavily raked prop, that will raise the bow.
Would it be easier to try a 0 rake prop than to modify the transom with tabs?
Postby Roberta » Tue Oct 11, 2016 3:47 pm
What prop would you suggest? I'm running a 13X13 four blade OJ (1" bore) full cup now. There aren't many props in this range available.
Postby kens » Tue Oct 11, 2016 4:04 pm
Roberta wrote:What prop would you suggest? I'm running a 13X13 four blade OJ (1" bore) full cup now. There aren't many props in this range available.
Say what???
1" props in the 13" & 14" sizes are made by all the prop makers, Michigan, OJ, ACME, and so on.
When I look for inboard props on Ebay, I cannot get away from all the different ski boat props………...
Try a 13x13 4bld without any rake.
Borrow one if you have to.
ACME has a good program where they fit you a prop until you are happy, if, you pay their price $$.
jenko
Postby jenko » Tue Oct 11, 2016 4:28 pm
I agree with kens the prop rake adjustment is the way to go.
It will more than likely be more efficient as well
Decreasing cup has a similar effect to decreasing aft rake ,also diameter changes boat attitude,
I would talk to a good prop shop
Postby Roberta » Tue Oct 11, 2016 4:55 pm
Looking at the MW, OJ, and Acme websites I find no info on rake for OJ and MW props. Acme sizes near what I need are listed at a 7 rake and only a 3 blade.
Postby Roberta » Tue Oct 11, 2016 5:09 pm
Also I am reading that the higher rake is better for speed. Lower and zero rake is intended more for slower work boats. I still think the trim tabs to poke the bow down at speeds above 40 is the solution.
Postby kens » Tue Oct 11, 2016 5:38 pm
Roberta wrote:Looking at the MW, OJ, and Acme websites I find no info on rake for OJ and MW props. Acme sizes near what I need are listed at a 7 rake and only a 3 blade.
Call ACME and talk them thru it. They have helped many people get the right prop.
Postby kens » Tue Oct 11, 2016 5:40 pm
And you don't know how much rake you got now, and don't know how much is in the other OJ's props.
OJ had better be able to tell you, if they know what their own stuff is.
jenko
Postby jenko » Tue Oct 11, 2016 6:30 pm
Roberta wrote:Also I am reading that the higher rake is better for speed. Lower and zero rake is intended more for slower work boats. I still think the trim tabs to poke the bow down at speeds above 40 is the solution.
drag boats us cleaver props which have no rake for stern lift
Anyway have a read of this http://continuouswave.com/whaler/reference/prop3.html
Postby kens » Wed Oct 12, 2016 3:40 am
Rake alone does not give or take away speed. It had more to do with running attitude. In your case, m if you get rid of the bow high attitude then you push the throttle up farther.
Your final top speed is the result of connecting given HP to the water, with whatever prop connects best.
Users browsing this forum: Bill Edmundson, ctboater and 23 guests
