SCARFING PLYWOOD
bobinpowayca
SCARFING PLYWOOD
Post by bobinpowayca »
Hi, I'm building the Geronimo. I plan on doing scarf joints, at least on the forward joint where the sheathing will have to flex a little bit. I've done a lot of research and most people say they use a block plane.
Seems to me a block plane being real short would make it harder to do the long flat planing for the scarf joint, then say a bench plane or a jack plane.
What do you folks that have done this think? What kind of plane did you use for making your scarf joints on plywood panels? Thanks! Bob
_______________
PBR support (1968)
Re: SCARFING PLYWOOD
Dont matter you call it a jack , bench, block or any other kind.
You use whatever one works on that day you use it.
The wood may have different grain as you get into it, and you swap out different tools.
All depends on the grain, your blade, or you work from the left or the right.
There is no one single answer.
thudpucker
Post by thudpucker »
In another century I built a Drifter in AK.
I made all my Scarf Joints with a Belt sander and a Straight edge. :roll:
What I learned is: If you get plenty of "Glue area" with no starving, you'll WIN!
None of my Scarf joints failed. The boat worked great. A guy bought the Boat and trailer from me at the end of it's first trip downriver. :o Now that's what I call a successful build! :mrgreen:
I built a Dog house once. The Dog wouldn't go in it! :lol:
slug
Post by slug »
I did mine on the Titan with a skill saw. worked OK and was satifactory. There are all sorts of methods, and if you search on the forum for scarfing you'll get some ideas about building various guides and jigs.
darthplywood
Post by darthplywood »
i bought one of these and it worked great. make sure you invest in a good quality blade for your circular saw. After you cut with this you will need to finish with a belt - sander. Worked great...even for an amateur like me!
I scarfed with a router. Ran the router on a long sled with the ply staggered in a stack.
