Any advise for installing shear on 19ft Tahoe.
Andy C
Post by Andy C » Wed Jan 08, 2014 8:59 am
Made it through chine logs and bottom battens. Scratching my head on how shear and shear clamps are installed.
John56
Re: Any advise for installing shear on 19ft Tahoe.
Post by John56 » Thu Jan 09, 2014 7:17 pm
Hang in there. Someone will be along with a good answer....
areame
Post by areame » Thu Jan 09, 2014 7:39 pm
I know there's a bit of a size difference but on my Squirt I went this route:
- Cut the sheer into 2 pieces to be laminated
- Soaked both pieces in a PVC pipe with water for a day (I just soaked the length that was making the bend)
- Starting at the breast hook, I made the bend using clamps every 5" or so for support, and ran the sheer to the transom
- Pre-drilled holes while the 1st sheer was still clamped on
- Let sit until the wood dried and then did the real thing by epoxying the sheer and using the pre-drilled screw holes and clamps for support
- Repeated the process with the second sheer lamination
Are you planning to do multiple laminations for the sheer or just steam one piece?
Post by Bill Edmundson » Thu Jan 09, 2014 7:59 pm
Andy
The sheers on the Tahoe are heavy. They're made up of at least 4 pieces. You will probably have to steam/hot bend them each one at a time.
Andy C
Post by Andy C » Thu Jan 09, 2014 8:12 pm
Thanks for the boost guys. Started notching and fitting the shear. I have been using Bill's photos to help me along. By the way Bill while viewing your photos my girlfriend thought I had posted pics of my boat!!! I plan on getting photos posted very soon!! Thanks for the replys
