Outboard Mounting Holes
I'm in the process of gluing the motor board to my transom and I want to make sure that I don't place any wood screws were the outboard will eventually mount.
I went online and was able to find the mounting hole distances from center for the Evinrude engines. It's a little over 6 inches at the top. The bottom is around 4 or 5 inches. But I can't seem to find the same information for Mercury engines which seems strange to me given the number of engines out there.
Anyway, I am not looking to drill these holes right now, I know that I can get a template or use the mounting bracket on whatever engine I end up purchasing. Mainly I just need to get some general idea of where these mounting holes will be so that I don't place wood screws in those locations.
Just as a point of reference. I'm planning on buying something in the 100 - 115 HP range. Probably an ETEC but I have not gotten to the point where I know for sure what it will be.
Thanks for any help
Re: Outboard Mounting Holes
From what I've been able to find, this is an AYBC standard pattern . The dimensions I found are
Top holes - 2" down from top of transom (cut out I assume?), 6-7/16" from center on each side
Bottom Holes - 8" down from top holes (10" from top of transom), 4-15/16" from center on each side.
I saw this dimension on the Evinrude pattern and saw a posting from another builder who measured an OMC outboard.
Fell free to weigh in on this.
Post by gdcarpenter »
No help here, running a 1959 Mercury Mark35A, old school clamps and all that. Seems, from what you wrote, you can run screws vertically down the center line, then keep clear 8"-10" either side of center. How many screws you plan on installing?
I basically did what gdcarpenter mentioned. Also had to determine approximately where the knee bolts would be .
I used enough screws to insure a good bond across the entire surface.This component will be under stress so I want to make it as strong as I can.
I don't have any way to clamp the center section other than screws so I want to use these. Not going to go overboard.
I'm not certain. I'll measure tomorrow. I think the Yamaha is 2" down from the transom to the top holes which are 10" apart. Then 8" down to the lower holes which are 8" apart. Don't drill yet :!: I haven't :!: But, for places not to put screws I think I can get that.
Bob Maskel
Post by Bob Maskel »
mrintense wrote:I'm in the process of gluing the motor board to my transom and I want to make sure that I don't place any wood screws were the outboard will eventually mount. Thanks for any help
Wow, why didn't I think of asking on here!! I am in the same mode...have held off attaching the horizontal 2X4 at the transom because I didn't want to run into any interference with the bottom motor mount bolts. I will be watching here closely to see what you find out. Thanks for posting this!
Sea Knight on the water/Malahini in progress
I just measured. These were taken in the boat yard from several boats in the 115 to 150 range. Others looked the same.
From the back edge of the transom:
Top hole were down 2" spread 13"
Bottom holes were down 10" spread 10"
Your mileage may very.
Bill Edmundson wrote:I just measured. These were taken in the boat yard from several boats in the 115 to 150 range. Others looked the same.
That sounds basically identical to the numbers I posted earlier. I think we can probably assume that they are an AYBC standard. Thanks for taking the time to do that Bill.
It's always good to get a confirmation from someone else. I also think it must be a standard.
Catbldr
Post by Catbldr »
I know this is a late post but since around 1985 the mounting holes are standardized. A 4 hole pattern. The template is online. Going to mount my transom knees and transom reinforcement tomorrow.
Brad Tucker
Post by Brad Tucker »
If it helps I can measure a 1994 MercuryXR 150hp
