Tunnel King Build
SJC
Tunnel King Build
Post by SJC »
I just registered on the forum here.
I received the Tunnel King plans about 3 weeks ago and have made some progress.
Re: Tunnel King Build
Welcome!! Look's really nice, so far!! Keep posting pics.
Roberta :D :D :D :D
SJC
Post by SJC »
Here are a couple of shots from last weekend. I have about 4 full days into the boat at this point.
SJC
Post by SJC »
There is a great write up about the Tunnel King in the Online Glen L newsletter, so I won't be posting too many how to instructions. But I will mention where I deviate from those instructions and why. I will be building the boat as designed, except where I screw things up :lol:
Supplies, ready to go. I really think the WEST Six-10 epoxy makes assembling parts very easy. So I have lots of that on hand.
Also I am using all Silicon bronze screws, no nails. And, of course, one can not have too many clamps!!!
SJC
Post by SJC »
A couple of shots of a joint on the transom. Some fun woodworking here. Skins are 1088 Okoume plywood, lumber is mostly Sapele with some Douglass Fir here and there to lighten thing up a bit. The Sapele is very heavy.
Cabron
Post by Cabron »
Nice collection of clamps you have. I like how you have them organized.
You were smart to buy all of your resin and adhesive all at once.
Pics are great. Your process of doing something, a product, a special tool.
I love them all and love to see other peoples techniques.
SJC
Post by SJC »
I saw some of the scarfing jigs and methods on other threads here. Wow. I just eyeball with a power plan then clean up with the Clifton.
SJC
Post by SJC »
With these two tools I have no trouble cutting in the notches for chine and sheer.
And a gratuitous shot of my last boatbuilding project with the Tunnel King in the background.
SJC
Post by SJC »
Last update for today. I epoxied the top side of the two tunnel pieces. Then installed them with two hundred or so screws. This is one area where I have deviated from the plans. Glen calls for fasteners every 2.5 " along the edges of the tunnel panels and 6" spacing in the battens. That would be 281 screws to secure a 3' x 16' piece of plywood. :shock: I have lots of faith in modern adhesives, so I changed the 2.5" to 4", still over 200 screws. 80 mph here we come!!! 8)
Looking Great!! Love the kayack, too!!
Roberta :D :D :D :D :D
SJC
Post by SJC »
Margaritas during boatbuilding?
No, I use my Vitamixer to make wood flour. I start with shavings from under the table saw run those in the Vitamixer for a few minutes and this becomes wood flour. I mix the flour with epoxy for a heavy, difficult to sand filler for fillets :lol: Hey it's free. and the color matches for those clearcoated areas.
tug
Post by tug »
I'm very much looking forward to following this build. I've always thought that if I build a fast boat this would be the one id choose.
LSaupe
Post by LSaupe »
Glad to see one of these being built. What do you plan in using for power?
SJC
Post by SJC »
My engine plans are for a 1970s Mercury Tower of Power. I have been talking with several folks over on Scream and Fly and the consensus seems to be that shortening the transom for a short shaft would be a good idea. A lower CG is rarely a bad thing. I have a line on a Merc 150 short shaft locally, so all of that is coming together.
I am doing some fiberglass work on the tunnel now. A few more days of filling and sanding and I should be ready to glass the tunnel. I am doing that before all of the other framing, such as the shear , because it will not be possible to work in the tunnel once the sponsons are built out without actually climbing onto the boat. In the current stage I can lean right into the tunnel and sand sand sand. :?
LSaupe
Post by LSaupe »
Sounds like a good combination. 150 HP should really make this thing scoot. Cant wait to get your ride report :o)
