Chugalug's BoJest
Re: Chugalug's BoJest
Post by chugalug » Thu May 03, 2018 5:10 pm
:D I'm definitely going easier next build.got the plans for waterlodge and super huck.might try shortening super huck toons a little for fishing barge.24 is a little long
Post by hoodman » Thu May 03, 2018 5:58 pm
Waterlodge has interested me for a while. No bending, cheap lumber.
CaptDave
Post by CaptDave » Thu May 03, 2018 7:31 pm
Yes, The Waterlodge would be much easier and probably quicker to build. Has any one ever built one? I cant' find any pictures.
Capt. Dave
Post by chugalug » Fri May 04, 2018 3:33 am
I wasn't too wild about their weight capacity(that was stated)6 people or 900 lbs .I'm not that skinny-It has capacity for 110 gal fuel tank tho.the only bending I can see on Super Huck,is the bow areas of the toons.looks like the taper is gradual.the bend on the bow of the Bo-Jest was pretty intense-and I used 2 layers of 1/4 ply instead of the 3/8's called for.coarse,maybe the staggering of joints and weaving edges didn't help ether? :D
Post by hoodman » Fri May 04, 2018 7:34 am
This is the only one I've seen pictures of. But they document the build pretty well. For a second build I think it would go fairly quickly if you had the space to build in a sheltered area.
http://peoplesriverhistory.us/project/the-shantyboat/
Post by chugalug » Fri May 04, 2018 5:12 pm
:D seems I saw a waterlodge build looking at all the older glen-l blogs.now I can't find it.
Post by mrintense » Sat May 05, 2018 3:28 pm
Boat's looking good Tim. Although I personally think the Waterlodge is too small, it was searching for pontoons and plans for a houseboat that first brought me to this forum and building my Vera Cruise. One thing for sure that I've learned with my cruiser. Building the hull is only about 30 percent of building a boat with a cabin. Outfitting it takes far longer. I think that although the Water Lodge might be simple to build, it will take quite a bit of time to outfit the cabin.
Post by chugalug » Sat May 05, 2018 8:19 pm
after reading the Ontario boat regs on marine toilets ,I'll have to change my mind on kittykat litter container and get holding tank and regular manual toilet.got keel guard yesterday .got horn ordered and carpet for rear area and pilothouse as well as one of these:
guess no boat is complete without one(according to Woodyboater)
CaptDave
Post by CaptDave » Mon May 07, 2018 10:09 am
Found Water Lodge Photos
Waterlodge Too from 2017 under Miscellaneaous in the Gallery
119 photos showing construction details
http://boatbuilders.glen-l.com/miscella ... o-Pollywog
You got me reading through the "A secret History of American River People" Blog
It gets you thinkin' about it
Capt. Dave
Post by chugalug » Mon Jun 11, 2018 10:26 am
:D Good news.gotta get carving-HIN # came in mail today along with title.Chug is now a 2018 model :D
CaptDave
Post by CaptDave » Mon Jun 11, 2018 10:37 am
Wow! A 2018 Model year Bo-Jest. That is good motivation to finish up. I look forward to the splash party.
Capt. Dave
Post by chugalug » Wed Jun 27, 2018 4:39 pm
:D Added a 110 buck chunk of bronze to "Chugs" hull today.was uneventful-drill 1-1/4" hole through hull,sand out a little,apply epoxy mix liberally to ply edges and thickened epoxy to fitting and assemble.
now I have to get screen from faucet to stuff in drain.getting closer to pulling out of the barn.now it can sit outside and I don't have to worry about alot of rainwater.Just have to remember to install plug before launching. :D
Post by hoodman » Wed Jun 27, 2018 7:47 pm
chugalug wrote:ust have to remember to install plug before launching. :D
Or shortly thereafter!
Post by mrintense » Sun Jul 01, 2018 1:48 pm
Congrats on the HIN number Tim. Getting closer now.
Post by chugalug » Sun Jul 01, 2018 4:00 pm
:D Been trying to wire the boat.Had to figure out where to put the 2 batteries.Finally settled on a sliding drawer under the motor.not too fancy but battery switch will mount on front and will be recessed enough so won't catch on anything. :D got hin # routered onto hull.Hope 1 inch tall letters and numbers are ok.
