Aussie Gentry
John R
Re: Aussie Gentry
Postby John R » Wed May 06, 2015 4:03 pm
G/Day thanks for the advice as yet i have not put the clips in the engine bay area yet and i was going to put them outside, but knowing me i would have made them the same all inside ha ha, so its good you chaps have jogged my memory thanks ....John
Re: Aussie Gentry
Postby Bill Edmundson » Wed May 06, 2015 6:17 pm
Look closely at the prints. My Tahoe shows them on the outside.
John R
Re: Aussie Gentry
Postby John R » Fri May 08, 2015 12:56 am
G/Day well all frames are now bolted / epoxy on double checked all alinements satisfied that i am just about spot on every where within 1/8" max anywhere, i will check all next before i put keel in and chines and sheers, made sure i put the clips on the outside of 2 and 3 frames ....John
John R
Re: Aussie Gentry
Postby John R » Thu May 28, 2015 3:41 am
G/Day well a bit more done the bottom stringers in (mostly) this allowed me to work better with out the chines in, i have also done the Limbers ....John
John R
Re: Aussie Gentry
Postby John R » Mon Jun 01, 2015 10:59 pm
G/Day well i got my 2 keels of Clear Oregon very nice machine job and timber i have now put the first one on let it completly cure before removing clamps, then i will fit second one ...John
John R
Re: Aussie Gentry
Postby John R » Wed Jun 03, 2015 7:16 pm
G/Day well not much done i got second keel down then i will shape ...John
Aussie
Re: Aussie Gentry
Postby Aussie » Wed Jun 03, 2015 11:54 pm
HI John,
Looking good mate!
Just wondering if you have had a look at Track happy's transom on his Gentry, i beleave that he changed it to flow more like a barrel back. (Looks real nice) I was also lucky enough to have a drive of the Gentry, only one of these type of runabouts that i have driven, handled great.
Its fun building, keep the photos coming.
Aussie (Jamie)
John R
Re: Aussie Gentry
Postby John R » Thu Jun 04, 2015 12:24 am
G/Day Jamie good to hear from you mate were are you from in Aussie, yes i am following a lot of Glenn but he says he pretty much went off the plans what was it like to drive and especially in the turns as it has no turn fin ....John
John R
Re: Aussie Gentry
Postby John R » Thu Jun 04, 2015 12:31 am
G/Day well clamp removed and did a bit of a match in to the transom crying as i did it because all up i am going to see $100.00 go in wood chip :lol: next time a bottle of wine, there is a lot to come off ....John
Aussie
Re: Aussie Gentry
Postby Aussie » Thu Jun 04, 2015 3:03 pm
Hi John,
Mate I am at Sarina (Near Mackay) in Queensland. Ever up this way welcome to drop in for a chat and a look at the Belle.
The water was a bit rough the day i had a drive of Glens boat Brandy, but turning didn't seem to have any issues and it docked nicely even in the rough water.
We are trying to arrange our third Gathering for this year (Check out the Gathering section in the forum). Location and date still undecided, if you have any suggestions please put them forward.
We all have to travel as we are so spread out around the country first gathering was Port Macquarie then Grafton.
I wont be ready again for this years gathering so i will be without boat ( am hoping to be finished in time for Christmas holidays to go boating.
Jamie
John R
Re: Aussie Gentry
Postby John R » Fri Jun 05, 2015 9:25 pm
G/Day well started to put guides in on the keel ready to fair, i faired some from the stem to keel ...John
Trackhappy
Re: Aussie Gentry
Postby Trackhappy » Mon Jun 22, 2015 8:30 pm
John R wrote:G/Day Jamie good to hear from you mate were are you from in Aussie, yes i am following a lot of Glenn but he says he pretty much went off the plans what was it like to drive and especially in the turns as it has no turn fin ....John
Hey John,
Jamie is right about me changing the rear, not so much the transom as the upper deck.
I hope I haven't misled you about going off the plans - I was talking about the hull itself. I did everything as per the book up to the rear deck, where I decided I didn't like the chunky "square back" look of the original, and made it one continuous curve from behind the seat to where it meets the transom. You have a ways until you get there, but do check out my pictures to see how it turned out. It caused me quite some head scratching but I am happy with the result.
John R
Re: Aussie Gentry
Postby John R » Wed Jul 15, 2015 6:26 pm
G/Day yes i will look at that when i get to that area, anyway the weather has been real bad here so not much done, but i did manage to Fair the keel in and finish cut and epoxy the Limbers, now just waiting on the chines and sheers to be machined to size i am using Oregon Clear, and have also sourced down my ply ...... John
John R
Re: Aussie Gentry
Postby John R » Sun Aug 16, 2015 3:11 am
G/Day well weather has been good purchased a heap of ply 4mm and 3mm Maple and Sapelle, so now first 2 sheets are now glued and screwed ....cheers John
John R
Re: Aussie Gentry
Postby John R » Wed Aug 19, 2015 12:17 am
G/Day well i got to the stem in 4 and a bit sheets (13" wide) all came around good i will glue and screw these tomorrow then do the other side ...John
