Aussie Gentry
Re: Aussie Gentry
Post by neel thompson »
John... You are a true craftsman... Very nice
Re: Aussie Gentry
Post by billy c »
Beautiful!
Get her launched :D
Re: Aussie Gentry
Post by PeterG »
Excellent!!
Re: Aussie Gentry
:shock: Simply beautiful.
John R
Re: Aussie Gentry
Post by John R »
G/Day thanks for you coments well screen fitted and all the fitting done on the rear hatch starting to look the part
John R
Re: Aussie Gentry
Post by John R »
John R
Re: Aussie Gentry
Post by John R »
Re: Aussie Gentry
John..... What hinges did you use on the aft hatch?
John R
Re: Aussie Gentry
Post by John R »
G/Day Neel they are a 316 S/S spring hatch stay about 220mm long and the ends pivot and rotate holds 4 kg each cost here $15.00AUD
John R
Re: Aussie Gentry
Post by John R »
G/Day well moving along have fitted the rest of the instruments fitted the alternator and made all the brackets and also the water pump all this is on a dummy engine, now i will start on engine parts like service the starter motor service the oil pump and distributor remember this engine is 1939 era
John R
Re: Aussie Gentry
Post by John R »
John R
Re: Aussie Gentry
Post by John R »
Milhouse
Re: Aussie Gentry
Post by Milhouse »
John R wrote:remember this engine is 1939 era
Wow I thought I had the oldest engine project with my 1962! you have a project there, very cool!
My sailboat may get this 2.5 HP 1936 Erinrude Sportwin 2 cylinder short shaft that I got running, its super interesting how simply these motors were designed :) vid here
Is that tiny brass guy a little water pump?
And if you want to get a new starter that is marine rated (i.e. spark sealed so you don't explode) I got mine at north county rebuilders in Escondido, CA, they ordered it from a guy that did a special nose for it so it mounted to my old block. Pics of mine old vs new and installed
I also see you are doing pulley steering, I am doing the same but mine are routed down both sides of the boat.
16' Ski Boat Restoration
17' Overnighter Sloop
John R
Re: Aussie Gentry
Post by John R »
G/Day yes that brass thingie is a Jabsco water pump yes i run them down the one side much easier that way, ok fitted the dummy engine in with all its parts on no issues at all and still lines up ...........John
John R
Re: Aussie Gentry
Post by John R »
