Aussie Gentry
sscobra
Re: Aussie Gentry
Postby sscobra » Sun Dec 13, 2015 10:43 pm
No, don't put the mahogany over the glass. Epoxy the mahogany to the plywood than glass over the mahogany. Skip
jamundsen
Re: Aussie Gentry
Postby jamundsen » Mon Dec 14, 2015 1:26 pm
Sscobra is correct
If the sides are to be bright I would use 4oz deck cloth on them and the 6 oz on the bottom
John Amundsen
Monte Carlo
Lakeland,Fl
John R
Re: Aussie Gentry
Postby John R » Mon Dec 14, 2015 9:17 pm
G/Day thanks for that Sscobra / Jamundsen i will only glass to the water line and the clear 2 pak on the timber proberly 6 to 8 coats ....John
John R
Re: Aussie Gentry
Postby John R » Wed Dec 16, 2015 1:48 am
G/Day well second skin going down using Bote-Cote thick epoxy works well and using staples, i dont know if you can get different gauge staples but standard leave to big a hole especially for the top Mahogany timber any suggestions ....John
jamundsen
Re: Aussie Gentry
Postby jamundsen » Wed Dec 16, 2015 1:26 pm
I used 18 gauge staples for the mahogany layer
I stapled thru a thin sacrificial piece of wood so I wouldn't damage the mahogany when I pulled them out. I pulled the staples about 8 to 10 hours later. If I waited longer they were much harder to pull. After a rough sanding I wet the wood with warm water several times. The holes vanished. I didn't use a long board for the sanding. I bought a Hutchins straight line sander. Don't buy the cheap imitations as they don't work. You will need lots of air to run the Hutchins sander if you go that route.
John Amundsen
Monte Carlo
Lakeland,Fl
jenko
Re: Aussie Gentry
Postby jenko » Wed Dec 16, 2015 11:34 pm
I did same as John except with 22 gauge staples
John R
Re: Aussie Gentry
Postby John R » Mon Jan 04, 2016 5:25 pm
G/Day thanks for that chaps well i have finished the first side wend down pretty well, before going to the other side i will put the last sheet of ply 6mm on the bottom this side (as this will be glassed) then continue forward latter with the Mahogany latter, does anyone know of suppliers of Mahogany in NSW i have 2 suppliers but 25mm thick ...........John
John R
Re: Aussie Gentry
Postby John R » Mon Jan 04, 2016 5:30 pm
G/Day when i purchased the engines (Q Dodge)i also got all the running gear as well so i have restored some of it ........John
jenko
Re: Aussie Gentry
Postby jenko » Mon Jan 04, 2016 7:15 pm
I got my mahogany veneer 4mm x 350mm for my king planks from Monaro timber Canberra
http://www.monarotimber.com.au/
They also sell other timbers and have large sizes and good milling facillities
John R
Re: Aussie Gentry
Postby John R » Sun Jan 10, 2016 11:36 pm
G/Day well started to put the last sheet 6mm ply on bottom scarfed 60mm to let the mahogany planks attach to, lots of weight on and staples, but went down well .....John
andycap
Re: Aussie Gentry
Postby andycap » Mon Jan 11, 2016 9:44 am
I love the ingenuous way to apply pressure on your second layer ply... I shall use that , tks
sands35
Re: Aussie Gentry
Postby sands35 » Mon Jan 11, 2016 1:01 pm
Bags of sand probably cost less than a box of staples!
Nice work!
tcough
Re: Aussie Gentry
Postby tcough » Mon Jan 11, 2016 1:21 pm
I like the tubs of water. Can be used for storage between boat projects!
Happy Boating,
Tracy
Building a 19'-9" Flats Flyer
John R
Re: Aussie Gentry
Postby John R » Tue Jan 12, 2016 3:29 pm
G/Day thanks guys yes the bags worked well as that was the 3rd layer of ply 6mm needed some weight on it
ADVICE ...............has anyone fitted a turn fin to the Gentry, does it require one
John R
Re: Aussie Gentry
Postby John R » Mon Feb 15, 2016 10:00 pm
G/Day well i have finished the 2nd skin all over now just waiting on some 6mm ply to do the other half of the bottom so all up 14mm thick, then i will do the rudder and prop shaft holes ........John
Users browsing this forum: danman, froberts and 6 guests
