Aussie Gentry
Re: Aussie Gentry
Postby mrintense » Tue Feb 16, 2016 6:43 am
Looking good John!
John R
Re: Aussie Gentry
Postby John R » Tue Feb 16, 2016 2:57 pm
G/Day well needed to get the water line marked so i could bring the 6mm ply to it and after the shaft holes go through i can glass to the water line, so being the curves it has i thought of a rotating laser level most were around the $300.00 mark no way i am only going to use it 2 times thought of hiring still to dear and i needed it for late afternoon so 2 days hire, so i found a new one on eBay for $50.00 and it worked a treat had both sides done in 30mins.......... John
Aussie
Re: Aussie Gentry
Postby Aussie » Tue Feb 16, 2016 11:44 pm
Hi John,
Progressing nicely...looking good.
Double and triple check that water line, i thought I had it right and was about to spray my undercoat and done a final check and realized i was out.
Glad i done a final check.
Bit of slow going for me at the moment but very happy with how things are turning out, by slowing down a bit I have changed my mind on a few things and think they are for the better.
Happy building.
Jamie
John R
Re: Aussie Gentry
Postby John R » Tue Mar 29, 2016 6:01 pm
G/Day yes Jamie this is just a rough water line mark so as i can finish the ply to and put 1st plank off Mahogany on so i can glass the bottom, ok my ply arrived so the full sheet went down now putting the ply planks on to the W/L mark then i will drill prop hole and rudder hole, getting the center by going underneath and drilling 1/8th hole where rudder and shaft holes will be through the hog
, also in my spare time i made solid Mahogany windscreen brackets and routed the slots and temp piece of material was used for depth ...John
jenko
Re: Aussie Gentry
Postby jenko » Tue Mar 29, 2016 6:52 pm
John, I also marked my first water line incorrectly I actually had 3 goes at it before I got it right
John R
Re: Aussie Gentry
Postby John R » Thu Mar 31, 2016 5:31 pm
G/Day yes Jenko yes i will do that for sure well i purchased a new toy now i have to learn how to use it, supposed to be a smooth cutter has 36 cutter blocks 3 rows in spiral shape so see how i go try it out on rubbish first.....John
jenko
Re: Aussie Gentry
Postby jenko » Thu Mar 31, 2016 5:44 pm
Nice .
I have bought a few tools from machinery warehouse and they have all been good quality
John R
Re: Aussie Gentry
Postby John R » Sat Apr 30, 2016 11:03 pm
G/Day well doing all the holes in the bottom now thats exciting better not stuff up so next week prop shaft hole will happen i hope, also made some serious wood clamps they do work well .......John
John R
Re: Aussie Gentry
Postby John R » Sat Apr 30, 2016 11:05 pm
jenko
Re: Aussie Gentry
Postby jenko » Sun May 01, 2016 12:05 am
looks great, Don't forget to put another block of wood on the inside to stop the bit wandering when it breaks through :)
slug
Re: Aussie Gentry
Postby slug » Sun May 01, 2016 4:21 am
John; How about a picture of those clamps? I'm intrigued.
John R
Re: Aussie Gentry
Postby John R » Tue May 03, 2016 12:25 am
G?Day yes Jenko i will do that ....Doug i made the fro 20mm (3/4") form work ply just drew a shape looked good so cut one out and tested got it right first time so i made a few and also changed the shape of some, the head on the arm which hold down the out side floats the inside one is fixed here are some pics the rule is 2ft ...John
John R
Re: Aussie Gentry
Postby John R » Tue May 03, 2016 12:29 am
John R
Re: Aussie Gentry
Postby John R » Tue May 03, 2016 12:30 am
slug
Re: Aussie Gentry
Postby slug » Tue May 03, 2016 4:16 am
John; Thanks for the pictures. Explains how you were obtaining clamping pressure as I couldn't figure it out in the first photo. I'm certain others will follow your lead. There are always some inventive clamping procedures in building a boat. (Sand bags?)
