transom frame batten notches
obd
Post by obd »
After a solid day of happily cutting frame notches, the beveled transom notches through me for a loop. I had my first, hopefully relatively minor, screw-up. The keel notch went well but, in spite of my efforts, I managed to cut a few of the batten notches about 1/8th of an inch too deep. I believe I could add a shim, add fairing material or cut a new transom frame piece and start over. Any advice? In general, are there any guidelines as to when fairing material or thickened epoxy will suffice for mistakes vs adding wood.
Re: transom frame batten notches
obd
I've used epoxy with fiber filler to "fix" many things.
Small shim will work, too. Manytimes a small shim or fairing away material will keep the fair lines of the boat. Just remember to glue both sides of the shim.
1/8 inch is not enough to warrant recutting a frame just butter up the shim wit epoxy.
