Center of balance
FFRCOBRA
Center of balance
Post by FFRCOBRA »
I have a question about motor placement and center of balance.
I'm building the belle isle and putting the motor in. The plans show the center of balance between frames three and four here:
With the motor hanging on a load leveler, the center of balance of the motor and trans would be the chain on the orange hook (from the hoist mounted above). You can see the center of balance marked on the boat between frames three and four. Do I simply line these two up and put the motor there? This position puts the motor further back about 4 or 5 inches than what the plans show. Image
Am I thinking correctly?
Thanks
Craig
sscobra
Re: Center of balance
Post by sscobra »
Craig, the center of balance on the plans is for the whole boat including the motor, not just the hull by itself. I would mount the motor as shown on the plans. There is some variance in weight between the different engine and transmission combinations, but I am sure the designer placed a typical engine as shown on the plans to achieve the center of balance. Once you get it in the water, if you don't like the way it sits (floats), you can add ballast in the bow or transom area to level it. Skip
Post by billy c »
try to get it installed as drawn, but if anything, mount the motor slightly back of the drawn location. make sure your running gear has proper angle and engine height fit under the deck as it is close. i think your PCM sits taller than my Merc
sands35
Post by sands35 »
If you need to adjust the CG of the boat, you have a big battery you can move around as well.
As Billy C said, if anything slightly back!
sands35
Post by sands35 »
Slightly back is simpler to trim out. Simple to move weight forward or add trim tabs. But if the CG is too far forward, it can't be trimmed out with trim tabs.
steveh41
Post by steveh41 »
Agree with all of the above. Would double check to see if any mods needed to frame 3 to clear the trans. prior to installation.
Frame 3 mods. are often needed. Be sure that you can get to the coupling and that you have room to get the packing nut open to replace packing.
Ozzieboat
Post by Ozzieboat »
FFRCOBRA
There is some good reading about "Centre of Buoyancy" in News Letter No. 100.
ozzieboat
FFRCOBRA
Post by FFRCOBRA »
Thanks everyone for the input. In my original post I said that lining up the two lines put the motor about 4-5 inches further back than the plans show.
Most of the responses say to mount it slightly back from drawn location or error to the 'slightly back' direction.
Will the 4 or 5 inches I mentioned equal the 'slightly back' position that others have mentioned?
One more question- if slightly back is more like 2-3 inches and I'm talking 4-5 inches....am I over thinking this? Ha!
Craig
Aussie
Post by Aussie »
Hi Craig,
Yeah mate, you are overthinking it... sometimes a good thing but can drive you nuts also...
At 23 ft long those few extra inches wont be that important... if you are between frame 3 and 4 give or take some you should be fine although back is better....
Some pics of where my engine sits in the Belle...
Jamie
