bow eye
svenole
bow eye
Postby svenole » Thu Apr 14, 2016 9:55 am
hi all ! I'm looking for a 8 or 10 inch bow eye the longest I have found is only 6 inchs and its to short and wont go though the breasthook. I thought of cutting the breasthook down but don't like that idea. thanks
Re: bow eye
Postby Roberta » Thu Apr 14, 2016 10:38 am
Glen L has a stainless steel bow eye that, I think, uses a threaded rod that could be removed and replaced with a longer one. You could get a longer rod locally. Typically the bow eyes go through the stem, not the breast hook.
svenole
Re: bow eye
Postby svenole » Thu Apr 14, 2016 11:00 am
thx
bobinpowayca
Re: bow eye
Postby bobinpowayca » Thu Apr 14, 2016 3:01 pm
On the subject of bow eyes, I just got my bow eye from Glen-L, it's the 6" long threaded portion one - I'm hoping it's long enough to go thru the stem on my Geronimo. I have a question - this is the first "through the boat" fitting I'm doing - what would be a good sealant? I figure you'd put sealant on the threads and in the hole and seat the eye in it on the steam. Any suggestions? Thanks, Bob
bow eye will go right between spray rails
_______________
PBR support (1968)
Re: bow eye
Postby Roberta » Thu Apr 14, 2016 3:29 pm
I would coat the drill hole with epoxy, then use 3M 4200 to pack up the hole and coat the threaded rod.
bobinpowayca
Re: bow eye
Postby bobinpowayca » Thu Apr 14, 2016 3:34 pm
Thanks Roberta!
_______________
PBR support (1968)
psychobilly
Re: bow eye
Postby psychobilly » Thu Apr 14, 2016 5:34 pm
I just cut and welded a piece of rod in between the Eye and Threads.
Butch Barto
Re: bow eye
Postby Butch Barto » Sat Apr 23, 2016 5:47 am
I just finished coaching my grandson building a 12' outboard river boat We just bored the bow post from inside large enough for the washer and nut still have plenty of wood left . I think I did the same on my Tahoe
Whitren
Re: bow eye
Postby Whitren » Mon Sep 05, 2016 7:16 am
svenole wrote:hi all ! I'm looking for a 8 or 10 inch bow eye the longest I have found is only 6 inchs and its to short and wont go though the breasthook. I thought of cutting the breasthook down but don't like that idea. thanks
you might break your breasthook if you cut it. try to look for other alternative to be safe.
