monaco ready to flip
Fair Dinkum
Re: monaco ready to flip
Post by Fair Dinkum »
Hi all, i have started to dry fit my engine. I have trimmed frame 6 to fit the sump, but in refitting the engine, I have noticed the remote oil connection protrudes 50mm beyond the sump. So three choices. Cut an appropriate hole in the keel and reinforce the keel. Bring the engine more forward and extend the shaft to meet it. Or replace the sump with a lower profile. Any ideas?
jenko
Post by jenko »
If the remote oil connection is just for draining I would move it to the side
I would leave the keel alone and make the sump fit.
That being said is the engine at the correct location? I would be hesitant at moving it forward if it is.
Post by Roberta »
It's hard to tell from the pics, but it look's to me that the engine assembly needs to come forward a bit and maybe angled more to meet the prop shaft. That might solve the drain plug issue. Most people use the dipstick tube to suck the oil out instead of draining from the bottom. You are probably aware that the floor timber needs more trimming to clear the bell housing. My plans called for that floor timber to be doubled up to provide reinforcement to counter the excessive trimming required for the engine and transmission. Not clear in the pics if yours is doubled. In any case, I would not alter the keel.
When fitting up my engine, I purchased a stainless steel tube in place of the prop shaft for fitting purposes. That way I could manipulate things to get the best fit-up and later determine the actual length prop shaft needed.
I'm concerned about the distance between the back of the coupling and the packing nut. Is there room the change the shaft packing?
Post by Roberta »
That caught my attention. too, Bill. That's what leads me to believe the motor is too far back. I think I would have a deck beam cut to see how much room I had to fit the motor under the deck. Sometimes without the deck beams in place, it look's like the engine may be too high. Often there is more room than appears. Glen designed these boats with the small block V8s and standard transmissions in mind, so they should fit, Typically the motor should fit just behind the frame in front of it, leaving room for a bulkhead partition.
Ozzieboat
Post by Ozzieboat »
Fair Dinkum
I think you engine location is fine. As Roberta said it's nice to have the engine behind a bulkhead partition that can be attached to frame 4. You may have to shorten the shaft log rubber hose to service the gland or alternately install a lip seal log. This one came from Cassell Marine. GL stock a similar type. Most ski/wake boats use them now. The blue hose is passing through Frame 2. With the oil drain obstruction can you remove it, install a low profile plug and suck the oil out through the dipstick tube? See Fynspray sump pumps.
Dave Grason
Post by Dave Grason »
Bill Edmundson wrote: Is there room the change the shaft packing?
How often does a straight shaft inboard NEED to have the packing replaced? I'm not being facetious. I honestly do not know.
It depends on several factures. How much you use the boat, how fast, how tight did you tighten the nut, what kind of packing... You can tighten the nut a few times. But, you will have to replace it.
Dave Grason
That makes sense.
Are we talking once a season or .... just to be safe or less often?
Jeez, I've been on this forum since the very beginning back in the late 90s and I'm, STILL learning new stuff like.. everyday.
Traditional packing drips about one per second to lubricate the shaft. If it leaks too much, you loosen the lock nut an tighten the packing nut. This may be as little as 1/4 to 1/2 turn. When you can no longer do this you need new packing.
Fair Dinkum
Hi all just an update on the mounting. I purchased some 120 x 120 dressed merbau hardwood and after 15 or 20 attemps for modifications i have finally epoxyed them in. I have anothe coat to finish them and some more epoxy to go, but I was excited by the results. they are m10 stainless bolts you can see. I test fitted the engine, the couplings go together by hand. I'm sure there will need to be some adjustments, but pretty close for now.
Dave Grason
Bill Edmundson wrote:Dave
I sure missed that when you first posted it. That's great to know and I have to admit that I did NOT know this before. Thanks
