subdeck material question
FFRCOBRA
Postby FFRCOBRA » Mon Oct 24, 2016 3:10 pm
Long time since an update, but all mechanicals are done. All interiors are done (no upholstery yet). Ready to put the deck on this thing and be done by next summer.
On the Belle Isle the covering boards are a full 3/4" thick. They do not use the thinner covering boar veneer. So the sub deck and finish deck must total 3/4".
At first I was going to use 3/8" plywood for the sub deck and then 3/8" strips on the deck. I could not find marine grade plywood in 3/8" locally. I ended up going to Home Depot and getting three sheets of the best 3/8" plywood I could find. I spent days cutting and trimming each piece. What a waste of time and money. The plywood started delaminating as I bent it over the gentle curve of the boat deck framing. Some areas are significantly softer than other areas. I just took it all back off and wondering what to do.
Here is a cross section sketch of the sub deck and strips up against the covering board.
I can get really good plywood (and expensive) in 1/2". Could I use 1/2" plywood and then 1/4" thick strips on the top? Like this:
All is not lost. I can easily use the bad 3/8" plywood sub deck pieces as templates to make new ones. So only out a little extra time and not too bad on the cost.
Anyone see issues with this?
Thanks
Craig
rleete
Re: subdeck material question
Postby rleete » Mon Oct 24, 2016 4:33 pm
That would actually be stronger. It may be a real pain to bend the extra thickness, though.
Aussie
Postby Aussie » Wed Nov 02, 2016 6:24 pm
Hi,
Like mentioned, you may have a bit of fun getting the 1/2" down. But would defiantly work fine.
I know I would have as I went another 1 1/2" of camber on my deck as I beleave that the deck was too flat for my liking.
I only went with a single layer of 6mm or 1/4" for the subdeck and also 1/4" for the planking, I just adjusted the height on the top of the frames to suit.
One day I will get back to building, just a little bit hard when you are over 3000klm from home and dont have much spare time at home when I am there.
I have even contemplated selling but think I would regret it!
Pic of subdeck and top camber attached.
Jamie
Postby mrintense » Thu Nov 03, 2016 6:31 am
Jamie, don't sell, you will definitely regret it. This is too much of a once in a lifetime experience that has your heart and soul in it.
Users browsing this forum: CarlM and 19 guests
