Rudder steering hardware question
Postby Jimbob » Fri Jan 20, 2017 10:08 am
Hi Everybody, more questions.
What hardware is used to connect the end of the steering cable to the tiller? Anything special?
Do I need a support tube for the cable next to the tiller? and how do most of you attach the support tube to the transom or that "thing" the rudder shaft goes through.
Does it hurt to order kit with excess cable? I am afraid I might come up short.
Re: Rudder steering hardware question
Postby billy c » Fri Jan 20, 2017 10:57 am
Jim if you are running the Teleflex cable you can use the part# and diagram below. you can waste a little cable in your run from the helm to the transom so if anything err about foot longer on the cable and adjust length by your routing.
Billy
Postby Jimbob » Fri Jan 20, 2017 11:00 am
Thanks!
Any ideas on where to buy? I can't find the parts at my usual online sources.
Jm
Postby billy c » Fri Jan 20, 2017 11:05 am
Google one of the part# i gave you and you will get about 20 marine dealers with the part :D
Postby Jimbob » Fri Jan 20, 2017 11:16 am
Thanks! Will be googlin'
One last question. Do I get the clevis kit with the short bolt or the long bolt? I'm using the glen-l tiller.
Postby billy c » Fri Jan 20, 2017 11:19 am
i'd grab the long bolt and put a few washers on it if needed.
Postby Jimbob » Fri Jan 20, 2017 11:55 am
Thanks for all your help! I found everything I need at Boatersplus.
Mr Hot Rod
Postby Mr Hot Rod » Fri Jan 20, 2017 3:09 pm
Ron Filsell's Tahoe 19 installation used an outboard splashwell mount and a custom bracket bolted to the stringer :
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Postby billy c » Fri Jan 20, 2017 4:07 pm
Jimbob wrote:Thanks for all your help! I found everything I need at Boatersplus.
great :D
Postby Jimbob » Mon Jan 23, 2017 10:28 am
Thanks Mr. Hotrod!
I really liked Ron Filsell's installation. Looks easy enough for me to do.
