Converting a missile to outboard
lakecat
Postby lakecat » Mon Feb 20, 2017 6:50 am
Hey folks, it's been a while. I've moved to Chicago and I've realized that the inboard I had been planning to build might not be the best boat now. There are lots of shallow waters here and my brother just bought a 19 foot deck boat. So I'm thinking about a little 16 foot outboard ski boat would fit the bill a little better. The rebel could be lengthened but has a pretty narrow beam. So I'm wondering if a missile could be rigged with an outboard? Does anyone know the depth of the transom?
I would pick the malahini but I'm looking for a design with a lot of tumblehome.
Re: Converting a missile to outboard
Postby Bill Edmundson » Mon Feb 20, 2017 7:15 am
lakecat
I think it could be done. But, it would depend on how big of an outboard.
lakecat
Postby lakecat » Mon Feb 20, 2017 7:22 am
I'm thinking about a 90 HP etec. I definitely don't want to under power the boat but I just want to pull skiers tubes etc and have fun with a few people on board. I'm assuming once I would shrink the motor stringers the hull would be close to the weight of a malahini. Am I in the right ballpark?
Postby Bill Edmundson » Mon Feb 20, 2017 8:44 am
Lakecat
Anything you saved on the stringers will go right back in to reinforce the transom and add a splash well. Power wise, I think you're about right.
E-Tec 90 weighs 320#. E-Tec 90 HO weighs 390#. Yamaha 4 stroke 90 weighs 366#. I don't know what a 5.0 liter engine + vee-drive would weigh.
I'm not a boat designer and I don't speak for Glen-L. This is just my opinion.
Postby chugalug » Mon Feb 20, 2017 9:12 am
:D How about using powerplant and drive from Sugar Sand jet boat or equivalent? :roll:
Nova SS
Postby Nova SS » Mon Feb 20, 2017 9:43 am
If I remember correctly believe someone did this exact thing, converting a missile to an outboard, several years back and posted about it here.
This is in one in the customer photo archive on here
http://www.glen-l.com/picboards/picboar ... 1086a.html
lakecat
Postby lakecat » Sat Feb 25, 2017 8:17 am
So, would I have to build a motorwell at all or would a bracket work?
Postby Bill Edmundson » Sat Feb 25, 2017 9:05 am
I would do a well. If water does slosh over the transom it can go back in the lake, not just swamp your boat.
BillW
Postby BillW » Sat Feb 25, 2017 12:43 pm
A bracket or "jack plate" type mount for a large outboard would place huge loads on the transom. In some installations
the motor is 6 inches or more behind the transom.
Therefore, you would have to strengthen the transom as if you were building a motor well in the first place. And you would still
need the self draining feature.
I think the Missile would be excellent; just be sure to angle the transom. The one in the picture would be ok for top speed,
but would not pull a skier out of deep water.
Postby hoodman » Sat Feb 25, 2017 1:00 pm
What about the stilleto?
Mr Hot Rod
Postby Mr Hot Rod » Sat Feb 25, 2017 1:48 pm
I found this photo on screamandfly.com. Transom is 90 degrees but the center section was inset at 15 degrees. This solves the outboard mounting issue and has a very clean look.
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
sproggy
Postby sproggy » Sun Feb 26, 2017 3:46 am
It's interesting to see a picture of that 'split transom' as I have been toying with a similar arrangement. However I was concerned about the stepped transom trailing edge and how it would affect the boat's performance on the plane. Any views on that? it must make some difference.
Mr Hot Rod
Postby Mr Hot Rod » Sun Feb 26, 2017 6:26 pm
We may have to get some input from Glen concerning the stepped transom trailing edge.
Or find another solution ...
Here are some photos from SJC's Tunnel King build. The transom is inset but the center section's bottom edge is flush with the transom edge.
Paul Kane
Chelsea, Quebec
BillW
Postby BillW » Sun Feb 26, 2017 8:29 pm
That offset in the bottom at the transom is not uncommon with high performance outboard boats.
For examples, see http://www.raveauboats.com
The offset provides a little "after plane" surface area; very little in the case of the yellow boat.
That yellow boat obviously needs more, therefore the large adjustable trim tabs, or after planes.
sproggy
Postby sproggy » Mon Feb 27, 2017 1:33 am
BillW wrote:That offset in the bottom at the transom is not uncommon with high performance outboard boats.
Lovely looking boats, those.
