GERONIMO bumper rail
Postby bobinpowayca » Fri Mar 10, 2017 9:18 pm
Howdy, here's where I'm at on my Geronimo build. I've got the bumper rail and toe rail done and primed on the starboard side - took a lot longer than I thought but the port side should take less time - I plan on using the belt sander more and my sanding boards less. I used two laminations of 1/2 inch thick by 1 1/4 inch wide white oak for the bumper rail, and made the toe rail a little wider than the plans - 4 inches wide and net 1 inch thick african mahogany. I radiused all the edges with a pocket router.
You can see kind of a "hump" along the side of the rail - at least it's the same on the other side - if anyone notices I'll explain this is a "hogged sheer" boat ( :wink: ), but it's not too noticeable. I can say one thing about this part of the build - any "unfair" lines along the side planking or decking will be real obvious when you're putting on the bumper rail. Lots of time with the sanding boards and some quick-faire.
I plan on painting the bumper rail and toe rail the same platinum as the spray rail, then a white deck. It's really solid - I don't plan on adding SS trim as it will be a lot easier to repair a nick in the oak than replace a section of trim. I would like to get a nice piece of steel to cover the stem cap from the breasthook to the front of the skeg, though. Don't know if SS can be bent.
Next will be the hatch which I've already got framed in under the deck. Bob
first coat of primer
solid front bumper
Built the Glen-L 17 (1988), Geronimo under construction (2013)
PBR support (1968)
Re: GERONIMO bumper rail
Postby joshuab » Fri Mar 10, 2017 10:35 pm
I want to move to where you are!!! Blue sky, palm trees, short sleeves......perfect, sign me up, your boat is looking great :!:
Postby Bill Edmundson » Sat Mar 11, 2017 7:09 am
Looks great!
If you do need SS these are the people to go to. They make the stuff for everybody else.
Postby hoodman » Sat Mar 11, 2017 4:00 pm
Looks great Bob. Thanks for paving the way for me!
Postby mrintense » Sat Mar 11, 2017 4:01 pm
Looking really good Bob.
