Halogen Fire Control Question
Postby Jimbob » Tue May 30, 2017 4:02 pm
Here's another question for you builders out there.
I remember seeing halogen fire control systems in offshore race boats. Has anyone used the system in some of the inboards we are building?
Sounds like a good idea but the ones I have seen are pretty pricey.
As always, your suggestions and comments are appreciated.
Ozzieboat
Re: Halogen Fire Control Question
Postby Ozzieboat » Thu Jun 01, 2017 4:38 pm
I was looking at installing a "Fireboy" system, but after thinking about it for a while (boat builders do that) I realized that a bigger concern was the big bang that you don't hear. So I installed two Gasoline Fume Detectors, one in the engine compartment and the other under the fuel tank. I bought them from West Marine.
Postby Jimbob » Fri Jun 02, 2017 2:58 pm
Thanks Ozzieboat!
You are absolutely right. A fire extinguisher isn't going to do any good if there is an explosion. Fumes explode. I think I will go with the fume detector and keep the extinguisher near the driver seat.
Postby TomB » Sat Jun 03, 2017 5:03 am
Jim,
You might consider adding a hole(s) sized for your extinguisher nozzle to squirt directly into a compartment without having to lift a hatch or remove a seat.
Users browsing this forum: No registered users and 12 guests
