16' Scooter Question(s)?
Rollbar
Postby Rollbar » Thu Jul 20, 2017 6:56 am
I'm thinking of this build (link below) 16' Scooter and wondering if my 25hp Merc 2S would push it well or if a total flat bottom would be best instead of the tunnel hull for the lower HP/25? I didn't see any min HP on the site page so I don't know one way or the other.
I can go either way for a fishing hull and would like to extend it by 10% LxW if it is doable for the HP I have as for now.
http://www.boatdesigns.com/16-Scooter-s ... ducts/486/
NAMEngJS
Re: 16' Scooter Question(s)?
Postby NAMEngJS » Thu Jul 20, 2017 12:44 pm
You will still be able to push her with a 25 HP Merc, granted not as quickly as the 120 that it is rated for. You may know this but incase you dont, FYI older engines were not rated at the prop like newer outboards, so that 120hp when the vessel was designed would be less at the prop. Most vessels can be increased 10% in length simply, not saying that beam cant be done as this is a simpler hull (not as much shape where the lines could be come unfair in a more moulded hull form.
Also, IMO I would keep it a tunnel hull, the tunnel effectively allows you to have the prop shallower while maintaining full immersion. If it were a flat bottom vessel you would have to make sure the prop and cavitation plate were below the transom bottom edge or risk cavitation, or go with another outboard option like a surface piercing prop or a gator tail.
Rollbar
Postby Rollbar » Thu Jul 20, 2017 12:57 pm
Thanks for the reply and information. Wondering what speed I could see out of the 25? Hoping at least 20mph but if I go 10%+ then ?? I was thinking that the tunnel would be less buoyant and longer to get on plane but it would help in cornering etc. Like you said, I can run the motor a little higher and with out a jack-plate I'm thinking.
'94 25hp Merc 2S 15" and with that, I think I can build the transom w/the 20" height and still be ok in the water UNLESS I'm not understanding the tunnel correctly. Wouldn't building the transom that way put me were a 5" jack-plate would put me anyway, or do I still need the motor adjustable?
Thanks for the help,
Rollbar
Postby Rollbar » Thu Jul 20, 2017 5:52 pm
Okoume/Weight-Light/Strength-Not strong/Decay and Rot Resistance-Poor/Fastening Ability-Fair/Comments-Suitable for light, small boats.
The Hull weight on the web site for the 16' Scooter states (approx.) 600 lbs.
1. Can anyone answer what the OEM used as far as wood to get their hull weight of 600lbs?
2. Question, if I use Okoume what weight is expected building the Scooter?
http://www.glen-l.com/designs/special/scooter.html
http://www.glen-l.com/wood-plywood/bb-chap5e.html
Postby Bill Edmundson » Fri Jul 21, 2017 6:28 am
This will give you an idea. This total running weight (Including ice chest)/HP. http://www.glen-l.com/how-fast/
Rollbar
Postby Rollbar » Fri Jul 21, 2017 7:15 am
Bill Edmundson wrote:Jim
Awesome thanks. I'll take a look at it.
Rollbar
Postby Rollbar » Fri Jul 21, 2017 7:19 pm
Question on the Tunnel Hull and drainage.
In your opinion, would it be best to put a drain plug (screw-in type) on each side of the hull just in case?
Rollbar
Postby Rollbar » Mon Jul 24, 2017 2:21 pm
Ok thanks for the help everyone.
Just ordered the plans for the 16' Scooter. :mrgreen:
Users browsing this forum: Bill Edmundson and 16 guests
