Neel's Palm Beach 22 build
Post by neel thompson » Fri Jun 01, 2018 2:13 pm
Finished bend
Post by kens » Fri Jun 01, 2018 2:19 pm
Neel,
I been building a strip canoe for awhile now, and I was steam bending many pieces.
The designer was telling me you dont need the steam, just the heat, he says he only uses a heat gun to bend parts.
I tried it, and he is right. I bought a decent heat gun for the task, and then put away all the steam, water, hoses, bags, containers, wrappings, and etc.
BayouBengal
Post by BayouBengal » Fri Jun 01, 2018 2:46 pm
That's convenient to know, Ken. Is the wood dry when you apply the heat gun, or do you soak it first?
Post by kens » Fri Jun 01, 2018 6:46 pm
dry wood,,,, it works. although on a tough piece it may take on a toasty look......
Post by mrintense » Sat Jun 02, 2018 5:15 am
Yes I liked that steam bag approach as well. It worked well me when getting my chines into position.
Neel, making very quick progress here. Looking great!
Post by billy c » Sat Jun 02, 2018 5:23 am
Neel-
nice to see the stem assembly getting tied into the frames. Sure is a sleek looking hull :D
Billy
Post by neel thompson » Sun Jun 03, 2018 5:59 am
Thanks Carl and Billy. I had a slight setback yesterday with the sheer. After steaming, clamping, and letting it cool, it looked horrible. The problem is that it not only has to bend, but also twist and other things. So I started over... This time without steam. I ripped a 14' x 2 1/2 x 9/16 in half back to about eight feet from the aft end. Then I glued and used ratchet straps to pull the first half-piece into place. After the glue set up, I pulled the second half in and glued/clamped it. This should work. I liked the steaming process, but will not be using it for compound bends. I should be able to use most of the board I screwed up somewhere....
Post by Bill Edmundson » Sun Jun 03, 2018 7:11 am
Neel
That bend and twist is a real PITA! I faced that eight places on the Bartender.
download/file.php?id=5348&t=1
Post by neel thompson » Sun Jun 03, 2018 8:17 am
You took the words right out of my mouth Bill.... Looking back at the pictures, I don't think I have two clamps that are the same... Carl puts me to shame in the clamp department !! Also, I don't measure between clamps for uniformity as he does. I wish he would come to a Gathering.... We need to meet him !!
Post by mrintense » Sun Jun 03, 2018 9:30 am
I only have a lot of clamps because I bought a few at a time from harbor freight. At 4 dollars a piece its not too hard.
I would like to come to the Gathering but need to handle some other issues in my life right now and try and get the boat done at the same time. Just can't afford all the hits on my wallet and fit in a lengthy trip. Please forgive me, I am not trying to be anti-social. :D :D
Post by neel thompson » Sun Jun 03, 2018 11:48 am
You're forgiven Carl. You will get there someday, I'm sure.
Post by hoodman » Mon Jun 04, 2018 6:36 am
Carl might be a little OCD with his clamps. But hey, if it works?!
Post by neel thompson » Mon Jun 04, 2018 7:36 am
I really enjoy reading and looking at pictures of his build. He really thinks ahead and plans everything out. He says he doesn't, but I would bet he measures between those clamps. He's gotta !!
I have made some progress on the sheer. I got the starboard sheer guled on from stem to transom, and I have the first ripped piece of the port sheer fitted and ready to be glued to the frames.
Post by mrintense » Mon Jun 04, 2018 8:29 am
Hey Neel.,check out my last post on my build thread. You'll see
I get the clamps set correctly. :D
Post by neel thompson » Fri Jun 08, 2018 4:16 am
After alot of coaxing with clamps and ratchet straps, the sheer is attached all the way around. I have two of the three laminations of the chine on and the third and final one will be going on in the next day or two. She is starting to take shape !! I ordered the mahogany for the battens yesterday and should have it next week.
