Neel's Palm Beach 22 build
c wright
Post by c wright » Sun Aug 05, 2018 5:18 am
Hi Neel,
Happened to find you build so thought you might like to see my completed PB. Power 454 Mecruiser 340bhp 1998 build off lofted plans. Chris
Post by neel thompson » Sun Aug 05, 2018 1:46 pm
Thanks Chris.... I saw a video of Obsession when she was up for sale I think. I hope mine turns out that nice. Where are you located? Neel
c wright
Post by c wright » Sun Aug 05, 2018 2:54 pm
Hi Neel,
I'm located in UK Suffolk Woodbridge, she is up for sale still at present as I also have this serious piece of kit. Chris
Post by neel thompson » Mon Aug 06, 2018 3:30 am
Very nice Chris.
Post by Bill Edmundson » Mon Aug 06, 2018 5:30 am
Chris
The second boat looks like a BIG Bartender!
Post by DrBryanJ » Wed Aug 08, 2018 5:37 am
Neel: Did you order your plywood yet?
Post by neel thompson » Wed Aug 08, 2018 6:22 am
Not yet Bryan. Getting close to that point though...
Post by DrBryanJ » Wed Aug 08, 2018 9:47 am
Before you do, I think I need three more 1/8 pieces of ply. I was wondering if I could tack in on your order and come pick it up from you?
Post by neel thompson » Wed Aug 08, 2018 12:48 pm
Bryan,,, I always get my plywood from Russell Plywood in New Castle, DE. I go down and pick it up. I would be happy to pick up the 1/8" pieces you need, but not sure how soon I will be going. It may be 2 weeks or so before I can get down there. If you need it right away, I probably won't be of much help to you. Just let me know.... Neel
Post by DrBryanJ » Thu Aug 09, 2018 4:26 am
Thanks Neel. I won't need it until after I flip the boat and at my pace that maybe two years.
Post by neel thompson » Thu Aug 09, 2018 6:41 am
Bryan--- I will let you know when I am ready to order and we will add yours to the list.
I finally finished encapsulating the side battens and have glued them in place and started the frame/batten fairing process. This will take a while and I'm really not looking forward to it. It is still hot here !! The pictures look like the last batch, but everything is glued now.
BillJ
Post by BillJ » Thu Aug 09, 2018 7:36 am
Neel,
I'd have to stop, screw some j hooks in, and hang it from the ceiling as is. Far too pretty to plywood over.
BillJ
Post by neel thompson » Sun Aug 12, 2018 10:27 am
I spent about six or so hours this weekend fairing everything. I used my six inch RO sander with 24 grit sandpaper to get it very close to being acceptable. I'm going to switch to 40 grit next and then 80. There were many short sessions with the sander, working in small sections, and then walking back to eyeball the area. The more I did it, fewer eyeballing trips were required. It's like you start to get a feel for how much to take off.
Post by Bill Edmundson » Sun Aug 12, 2018 11:04 am
Neel
I find "Feel" to be so true. I often close my eyes and see with my fingertips.
Post by kens » Sun Aug 12, 2018 12:49 pm
I took a hand plane, drilled/tapped 2 holes on each side face, then screwed on a extension leg of hardwood to go outward enough to land on adjacent longitudinal. (like a outrigger)
The extension leg would lay on adjacent longitudinal, and I worked the plane on the other longitudinal.
Draw a centerline on the part you are working and never plane past the center line.
This worked well for me.
