Squirt Sheer Issue
Re: Squirt Sheer Issue
Post by Hercdrvr » Thu Jun 07, 2018 7:12 pm
20hp is great, tops out at 29mph. Yamaha has a new 25hp out that weighs same as a 20hp. That would be my choice.
wsquam
Post by wsquam » Mon Aug 27, 2018 8:00 pm
Fatal Error?
So I used the nails 6 inches on center, for the second lamination of the sheer, but as I read after the fact in the boat building with plywood book that these should be nailed from the inside. Makes sense. I have no idea how I am going to fair this now.
Any suggestions
Post by hoodman » Mon Aug 27, 2018 8:43 pm
Most tools that folks commonly use for fairing will go right through those SB nails.
Post by JimmY » Mon Aug 27, 2018 8:50 pm
Beltsander. Planes are out unless you want to become an expert in sharpening. :D
Biss
Post by Biss » Tue Aug 28, 2018 3:37 am
Angle grinder with flapper disc. I sanded through a few nails in my gussets while fairing with no issues.
Two8nine
Post by Two8nine » Tue Aug 28, 2018 9:34 am
Biss wrote:Angle grinder with flapper disc. I sanded through a few nails in my gussets while fairing with no issues.
Seconded. I couldn't get a satisfactory clamping job on the first laminations of my sheer, so I screwed it down between the laminations, the angle grinder ate through the #10 screws just as quick as the wood.
Out of curiosity though I'm curious how many recommend the screws/nails between laminations at all? I only put screws at the frame junctions, and only after fairing in most cases. Everything else is epoxy.
Post by TomB » Tue Aug 28, 2018 1:13 pm
It probably depends on the boat. My plans call for screws every 6" along the sheer lamination in addition to at the frames. I was concerned about cracking at the screw hole and plane damage during faring so I waited until I had a planking layer on add the screws.
Post by hoodman » Tue Aug 28, 2018 5:35 pm
My sheer laminations don't have any fasteners. I just used a "boatload" of clamps.
Post by Hercdrvr » Tue Aug 28, 2018 6:09 pm
Poxygrip and clamps. Screws and nails just get in the way during fairing. Only one screw at each frame.
Post by Hercdrvr » Tue Aug 28, 2018 6:13 pm
The way I look at, I put the screws in the laminations when the planking goes on and running into an existing screw while attaching the planking sucks!
wsquam
Post by wsquam » Tue Aug 28, 2018 7:54 pm
Thank you everyone.
Ryan
