Biss's Malahini Build
Biss
Post by Biss »
Started my build last month, so I thought I'd post some updates. Got my lumber from Phillips Forrest Products over in TX. It is African Mahogany.
African Mahogany lumber
Patterened and cut/planed the various frames. Since my lumber was 5/4, I planed to a full 1 in.
Cut/planed frames
Cut/planed frames
Built all the frames and building form. I used 3/8 Okoume for the gusset material. Was able to source marine ply locally at Little Rock Boat Builders Supply!
Frames, stem,  etc. on form
Biss
Re: Biss's Malahini Build
Post by Biss »
Next I milled the keel, chines, shears and used scarf joints as required. Then laminated the keel with ply and began fitting the shear/chines. I actually used a reciprocating saw for the forward (frame 4) notch cutting which worked really well.
During the fitting of the chine, I used the full thickness so I did the the towel/hot water trick. Worked exactly as advertised!
Towel/hot water chine bending
Dry fit
Dry fit
After fitting everything, I removed the transome and glued it. After glue cured I reinstalled the transome to the building form and glued the shear, chine, and keel in place.
Shear lamination glue up.
Next step appears to be fairing! Everything is going pretty good, thanks to the excellent plans and the wealth of info on this forum.
Post by DrBryanJ »
Very nice work. You are moving along quickly.
Boytoy
Post by Boytoy »
Looks great! :D
Biss
Post by Biss »
Thanks guys. I started faring the aft end of the boat yesterday. Did the easy stuff up to frame 4! It appears to get a little more complicated forward of that. Lots of good info on the forum to help, but if anyone has tips for faring frame 4 forward I'd be happy to hear them!
Post by PeterG »
Wow, you've made great progress in a short time. And that's a great shop you have.
I highly recommend using battens to monitor your progress when fairing, for instance you could try long 3/4" square stock about 8-10 ft long or you can use a strip of 3/8" plywood about 2" wide and 8' long. Use it lengthwise on your hull framework and weigh it down in place or lightly clamp it to get a view of the bevel angles you want to fair the edges of the frames to. For the bottom, use the batten parallel to the keel, for the sides use it parallel to the sheer, working it in intervals along the frame edges. There won't be a constant bevel angle on the frame edges when you move from the keel to the chines or from chines to sheers, that's where the batten helps visualize it. Save the batten or strip for fairing your deck, lengthwise and across the hull.
Brad Tucker
Post by Brad Tucker »
That is looking great!
Biss
Post by Biss »
Good advice, I have been using a straight edge and a strip of 3/8 ply for checking my work. I pretty much have the bottom side, chine to keel/stem roughed in. I used the Rabl method on the area forward of frame 4; seemed to work pretty well.
I think I will probably give my lungs a rest for a day or so before diving into the shear fairing! I have been wearing a dust mask, so i hope the inside of my lungs dont look like the inside of my shop! The angle grinder is quick, but makes a huge mess.
Post by PeterG »
Sounds great and bravo for wearing a dust mask. It'll help keep your lungs from being irritated and keeps your sneezes from grossing out others.
I'm watching your build closely, I've been building a Malahini too, have a huge pile of parts and supplies waiting for me to assemble it.
Milhouse
Post by Milhouse »
I just saw the CNC and what looks like a wooden Clayton Boyer Clock in the back. Nice!!!
16' Ski Boat Restoration
17' Overnighter Sloop
Biss
Post by Biss »
Good eye! Built the cnc and clock several years ago. The cnc is a Joe's 2006 diy design. Fun and capable little machine! The clock was a fun build too. Its not really practical as a time piece, but is cool to watch it operate! I also built a mechanical display that uses the grasshopper mechanism. Thats ever cooler to see operate; its on a shelf in my office. Sounds like you are familiar with the wooden clocks, have built one before?
Milhouse
Post by Milhouse »
Very cool! I too built a Joes 4x4 CNC hybrid over a few years and completed it in 2013. I used it for a lot of fun stuff awhile ago and but I don't use it too much currently since I got my 150W laser that I use for 2D cuts for my Etsy side gig. I also started a Boyer clock (the Harmonic Oscilator) awhile with the CNC but didn't finish it (too many projects :) ) Maybe I'll get back to it when my boats are done :)
I am eager to see your boat take shape as your build progresses; you are making great progress!
Biss
Post by Biss »
Well, I think I'm pretty much done with faring the framework. Not my favorite part so far! My tools of destruction were a power planer, angle grinder, block plane, hand saw, reciprocating saw and RO sander! I should have had knee pads as well! Anyway I will be installing the transom knee next. the plans don't say anything about gluing, only bolts. Seems like it would be a good idea to epoxy and bolt.
Yeah you want glue on every joint boots or not.
Biss
Post by Biss »
Thanks Matt! Makes sense so I'll be gluing! Plan to fit and install tonight.
