Biss's Malahini Build
Re: Biss's Malahini Build
Post by Hercdrvr » Fri Apr 12, 2019 7:18 am
Exciting delivery you’ve got there. The 60 hp is nice motor on the Malahini. I had that same motor a few years back and I’m not sure it actually even uses gas, very efficient.
Post by PeterG » Fri Apr 12, 2019 11:26 am
Sweet! Bet that will purr like a kitten :)
Sarnian
Post by Sarnian » Fri Apr 12, 2019 11:53 am
absolutely fantastic....
Post by hoodman » Fri Apr 12, 2019 6:04 pm
Those are great engines. I'm sure you'll be happy with it.
Biss
Post by Biss » Sat Apr 20, 2019 7:05 pm
So I've spent the week doing several different things. I put a coat of paint on my trailer. Looks like it is going to need a second coat. I got a wiring harness installed and most of the remaining electrical complete. Also installed the steering and controls. Had to fabricate a 2" 'riser' for the controls so the cables could better make the turn out of the bottom. I also made some patterns for the cutwater and transom bands. Hope to get those fabricated this week. Getting closer to being able to start the deck!
Controls installed
Cutwater
Transom band
Biss
Post by Biss » Sat Apr 20, 2019 7:12 pm
Few more pics
Lighting
Steering/control cables and harness
Post by billy c » Sat Apr 20, 2019 7:21 pm
That's coming along really sweet! That 60 will push that along nicely.
Are you going to fabricate a cap for the top of the cutwater also? If not it might be good to make the cutwater top a little taller so it can tuck under the rub rail.
Biss
Post by Biss » Sun Apr 21, 2019 6:28 am
Thanks Billy, I wasn't really sure what to do on the cutwater. I might make a second diamond shaped piece that will fit over the deck/ rub rail ends. Or might just make a v shaped termination piece out of rubrail. Not sure how it is typically done...anybody have suggestions?
Post by Jimbob » Sun Apr 21, 2019 8:21 am
Here's a couple of examples of how chris craft covered the top of the cutwater with a fairleader. Depending on the year of the boat, they used one of the two examples below. The main thing is they have a lip on the front that covers the top of the cutwater. The rub rails but against the cutwater. I have seen boats where people have made a triangular piece on top of the cutwater. I have an extra fairleader that might fit the bow of your boat. Send me a P.M. and I can send you a pattern to check the fit.
Biss
Post by Biss » Sun Apr 21, 2019 6:52 pm
Thanks Jim. Pictures really help!
footer
Post by footer » Mon Apr 22, 2019 3:29 am
Man, it's looking beautiful. I love the lighting. I have LED strip lighting on my pontoon, I didn't even think about it for my Malahini.
Biss
Post by Biss » Mon Apr 22, 2019 7:13 pm
Yeah, the led lights are dirt cheap and really easy to install.
Biss
Post by Biss » Wed May 01, 2019 6:54 pm
So, I have the electrical pretty much complete. I hooked my motor up, electrically, and tested out the wiring/accessories, it seems everthing is working properly. Pretty jazzed about that, so I have moved on to fitting the plywood subdeck. I hope to get it glued down this weekend. Oh, by the way, I was able to do the entire deck with just two sheets of ply; nothing left over but sawdust! A few pics follow...
Post by hoodman » Thu May 02, 2019 5:20 am
Nice! Two sheets huh? That's impressive. You gunning for a summer launch?
Biss
Post by Biss » Thu May 02, 2019 6:56 am
Thanks, Yeah, I'm hoping to have it in the water this "summer." Luckily summer doesn't end until late September!!
