Key West design speed in knots
rblevens
Post by rblevens » Sun Aug 12, 2018 8:34 pm
What top speed in knots was the Key West hull designed to safely operate?
What is it design cruise speed?
35 knots?
50 knots?
Will be using a 7.4 with ~300 hp and a 1:1 gear.
Thanks
Rick
Re: Key West design speed in knots
Post by Bill Edmundson » Mon Aug 13, 2018 9:46 am
Rick
The Key West at max weight and 300hp could run about 45 MPH or 39 knots. You said 1:1, I don't know your WOT for that engine. About the max shaft RPM for a 12" dia.. prop is 4000. It's about 3700 for a 13" prop. After those numbers you start getting blade tip cavitation. You could go to a reduction gear and more pitch on the blade.
rblevens
Post by rblevens » Thu Aug 16, 2018 5:52 am
Thanks Bill- they say the design was 31 knots which seemed a bit slow- but I don't want it breaking up either... ?
What was your max weight number? (With people onboard)?
Post by Bill Edmundson » Thu Aug 16, 2018 6:05 am
Rick
I used the displacement weight. Displacement is the max. safe design weight of everything, the boat, people, gear, engine, fuel... Think it was 4000#.
