flex coupling question
Post by Jimbob »
Has anyone had any experience with a flex coupling. It goes between the transmission and the prop shaft coupling. They say it eliminates vibration, protects the gears, and works like a u-joint if your alignment is slightly off. Good idea? or a waste of money?
Pic below:
Re: flex coupling question
Post by neel thompson »
Jim,, I have one on my Gentry and I know Roberta has one on her Torpedo. I don't have any vibration, but I have never run the boat without the flexible coupling. So I don't know if I would have the same results without it. I guess it's a good thing to have.
I don't have one on the Tahoe. Seems to run fine. I thought about it a long time. I do think it is probably a good thing.
neel thompson wrote:Jim,, I have one on my Gentry and I know Roberta has one on her Torpedo. I don't have any vibration, but I have never run the boat without the flexible coupling. So I don't know if I would have the same results without it. I guess it's a good thing to have.
I got one too.....and also never run without it.
I suppose somebody has to run up on the rocks to find out if it really works.!!!!!
Brad Tucker
Post by Brad Tucker »
I run one, as well
sscobra
Post by sscobra »
I put one on my Monaco...no vibration. Skip
Post by PeterG »
It couldn't hurt to use one. It will push your prop further aft, so watch clearances back there. In fact a flex coupling might helpful too, especially if you run a down angle transmission. You get your shaft/transmission coupling flanges aligned just right with the boat sitting in the water. Then you run it across the lake where you get a little hull flexing (happens to all boats) and a little torque twist of the engine on it's motor mounts, that's bound to affect alignment. On straight shaft boats with inline transmissions, it's not much of an issue as the shaft is supported by the strut and the transmission, and torque twist is all on the same axis of the shaft through the transmission and engine. The transmission flange stays centered on the axis of shaft and engine rotation; and the shaft log/shaft seal have the flexible tube to prevent shaft binding even if the hull flexes. But with a down angle transmission, the engine torque twist is not on the same axis as the prop shaft. The transmission flange swings a bit to the side, off of the shaft's axis, dragging the prop shaft with it and pulling the coupling flanges out of parallel. This is when the flex coupling helps by allowing this motion to occur without binding the shaft or stressing the coupling flanges. I would not run any down angle transmission in a boat without it.
Post by Jimbob »
Thanks everyone for your responses!
