Hi all. Life gets in the way of computer builds as well unfortunately. I’ve refaired and remodeled the frames and longitudinals since my last post and am currently working on sheathing and deck framing but figured I’d go ahead and post an update.
Unlike others, I was NOT able to secure permission to cut the side off our house!! However, I do have permission from Mrs. NYBHH to move forward with building a larger outbuilding/shop where a 25' boat could actually be built so I've started working on the design of that as well. I've wanted a larger shop for a while so this is really just a good excuse to go ahead and make it happen. We're going to build it as an extension off of our barn so I'm hoping the permitting/tax implications will be minimal. This project is still a ways away from becoming a reality.
I am starting to really appreciate the Bolero design and it has some beautiful lines. Other than some deck and cockpit modifications, I think the majority of my design modifications will be limited to the transom and as little of frames 1 and 2 as required to maintain fairness. A bit of tumblehome would be very nice but would complicate the side sheathing considerably since it was designed as a "developable" surface for a 25' long scarfed panel of plywood. I do want to finish the boat in bright mahogany so there will be some decisions to be made with regard to hull sheathing modifications anyway.
Since there aren’t many Bolero builds out there to follow for more design detail, I’m going to try and relay some of the design details that one can normally get from a build thread here.
Frames
The Bolero frames are all specified as 5/4 lumber, shown here 1” thick. Frames 1-5 are built with side and bottom members joined with ⅜” plywood gussets both fore & aft of the hardwood frames. Frames 6 & 7 are single piece frames, up to 8” wide. Station spacing is 30". The transom is also 5/4 lumber made up of two layers at the bottom with only the inner layer notched to receive longitudinals.
Stem
The 2.25” thick Bolero stem is specified as 3 layers of ¾” plywood OR a ¾” plywood core with a layer of 4/4 hardwood on both sides of the plywood core.
Keel
The Bolero Keel is specified as two laminated layers of 4/4 x 6” hardwood. The keel is straight/horizontal (parallel to the setup level) from stations 0-4 before beginning to curve up towards the stem. The keel tapers to match the stem width forward of frame 6. This view really illustrates the deep-V hull on the Bolero with its 20-degree deadrise. I do think this is a great hull design for the waters where I intend to use her.
Floor Timbers
The Floor timbers are specified as 2 layers of ⅜” plywood on both sides of frames 1-5 with a 5/4 solid wood spacer that fills in the area between the timbers and frames. A single ¾” PW timber is specified for the aft-side of frames 6-8 that notches around the stem.
Longitudinals
The Bolero chine logs are specified as 5/4 x 3” and the Sheer is two laminated layers of 4/4 x 1-½”. The bottom battens are specified as 5/4 x 2-1/2”.
The bottom battens are probably one of the biggest departures I’ve seen from other boat builds I’ve followed here. The frames (except for frame #8) are NOT notched for the battens and the bottom sheathing is specifically designed to NOT fasten directly to the frames. If you look carefully, the bottom sheathing is designed to not even contact the bottom frames and only makes contact with the chine, battens and keel. The reason for this is discussed briefly in Mr. Witt’s Boatbuilding with Plywood but I still don’t completely understand why to be honest although it does eliminate the need for limbers.
I’m curious what other more experienced builders think about this but I’d be tempted to partially notch the frames, perhaps about ½” for the 1” thick bottom battens to help lock them into place to prevent overly stressing the batten fasteners with the understanding that the bottom frames will need to be a little thicker so the notch does not reduce their minimum dimensions. Hull sheathing could still not contact the frames and the frames could still be avoided with fasteners and limbers would still not be needed as well.
