Question about this build pic
WarrenW
Postby WarrenW » Thu May 17, 2007 10:59 am
Below is a picture from Guy Young's Malahini build in the customer photos. He seems to be doing a superb job! When he attached the plywood to the side as shown below, it looks like small square wood pieces with each fastener. Is this because he plans to remove the fasteners and fill in the holes? And he is butt blocking the sides right? I read another thread that its best to butt block but not on a frame but in between. Is this right?
Thanks
Warren
Building the Malahini
Soon to be named - It's a Bella
RobB
Postby RobB » Thu May 17, 2007 11:19 am
:D Thats exactly right. From what I've read so far fastening this way also helps if you dont have as many clamps as you would like, :roll: and who does :?: :D Never place the butt block at a frame junction, weak joint and leaks will follow, I have seen a build that did this, by the second season he had to go back and replank the boat. :cry:
Best wishes on your build can't wait to see it. :D
If you don't start heading that way today, tommorrow you won't be any closer to your destination.
Users browsing this forum: No registered users and 20 guests
