Florida Malahini Build
footer
Re: Florida Malahini Build
Post by footer » Tue Oct 08, 2019 4:21 am
Nice job on the side panels. I still have to do that this winter to mine.
Post by PeterG » Thu Oct 10, 2019 7:39 pm
Nice work! Moving right along. What's the second battery for, accessories?
altondavid
Post by altondavid » Mon Oct 14, 2019 8:42 am
Thank you!
I've got a dedicated starter battery, and then a deep cycle battery that's meant to be for accessories. It may be a bit overkill for the Malahini, but I figure better safe than sorry.
Post by PeterG » Tue Oct 15, 2019 3:19 am
I figured that was your plan, wasn't quite sure. You're making great progress!
Gayle Brantuk
Post by Gayle Brantuk » Wed Oct 16, 2019 2:08 pm
Very nice! Keep up the good work...
altondavid
Post by altondavid » Mon Oct 21, 2019 7:39 am
Thank you! Made some progress on the Decking. Deck is going to be Sapele with Cypress inlay. Covering boards went down first.
Followed by the king plank.
Then the first stripe of decking down
We modified what the plan calls for a bit - the covering boards start at 6.5" and taper down, the king plank is 5", and the decking is 2".
Post by PeterG » Tue Oct 22, 2019 9:05 pm
Very sharp, this will look great once the finish is on. Modifying what the plan calls for is allowed, actually it's why we build our own boats :D
footer
Post by footer » Fri Oct 25, 2019 4:44 pm
Good choice going with the wood strips. I used caulk, and although I got the pure white I wanted, it was about 70% more expensive. Looking forward to seeing yours finished.
altondavid
Post by altondavid » Tue Oct 29, 2019 9:58 am
I would definitely recommend this method, especially cypress, though I'm sure you'd get similar results with a similar, softer wood. The give in the cypress has made it easier to shape in the boards, and it creates a really tight fit that is turning out better than we had even hoped.
Here's some pics of the process we made this weekend:
CarlM
Post by CarlM » Tue Oct 29, 2019 10:39 am
Very sharp !!👍
footer
Post by footer » Wed Oct 30, 2019 6:47 am
Lots of holes to plug, but looks great.
altondavid
Post by altondavid » Mon Nov 04, 2019 11:02 am
Plugs, plugs, and more plugs. About 400 on the deck in total.
Sarnian
Post by Sarnian » Mon Nov 04, 2019 12:44 pm
That looks a bit freaky....kind of a freddy kruger look! :D
Looking fantastic - you guys are going great guns - congratulations!
Post by Hercdrvr » Mon Nov 04, 2019 3:29 pm
Very nice,
altondavid
Post by altondavid » Wed Dec 04, 2019 8:28 am
It's been a bit since my last update, but we've made a lot of progress in the last month. Plugs were all leveled out and much sanding completed.
Here you can see the bow after some sanding, but before the rail has been installed:
Here you can see some of the detail around the dash:
Here you can see some of the detail on the transom/motorwell:
