cepjr
Posts: 45 Joined: Mon Nov 19, 2018 6:00 pm
Post
by cepjr » Sat Apr 25, 2020 2:45 pm
Looks great ! Its not boat building its boat sanding!!!!!!!!!!!
Ga-Steve
Posts: 109 Joined: Thu Dec 27, 2018 5:28 pm
Post
by Ga-Steve » Sat Apr 25, 2020 3:15 pm
I might add that it was not level in the pic. I just have the level sitting there at the shear. Leveling at the keel/frame juncture.
Posts: 2678 Joined: Thu Nov 10, 2011 8:48 am
Post
by hoodman » Sat Apr 25, 2020 8:07 pm
Congrats on the flip. It's daunting but exciting now.
Gayle Brantuk
Posts: 1874 Joined: Tue Nov 11, 2003 1:02 pm
Post
by Gayle Brantuk » Mon Apr 27, 2020 11:47 am
Ditto from me--congratulations! I doubt that drips are uncommon--just a pain!
Ga-Steve
Post
by Ga-Steve » Mon Apr 27, 2020 3:51 pm
Sanding, planing on the sheer. Seems the tool of choice to keep the line smooth and flowing is a Shinto saw rasp. This tool is amazing.
Ga-Steve
Post
by Ga-Steve » Wed Apr 29, 2020 1:05 pm
Both carlings installed. Starboard faired, fixing to start on port side after the rain. Need to add additional blocking from sheer to carlings.Having a time trying to find a trailer. Steve
Posts: 12051 Joined: Wed Nov 23, 2005 6:45 am
Post
by Bill Edmundson » Wed Apr 29, 2020 1:28 pm
You won't need more blocking when the deck goes on.
Ga-Steve
Post
by Ga-Steve » Wed Apr 29, 2020 3:43 pm
I posted this in the painting section but didn’t get a response. Just wondering any thoughts on using DryLok waterproofing paint on the bilge. It says it is for masonary but why wouldn’t it work on wood? Would be far cheaper than the 2 part paints. Steve
Post
by hoodman » Wed Apr 29, 2020 4:09 pm
I don't have anything in my bilge but epoxy.
footer
Posts: 414 Joined: Wed Jan 24, 2018 6:28 am
Post
by footer » Thu Apr 30, 2020 7:56 pm
I can’t say how it would work, but the dry lock I used in my basement had texture in it.
Ga-Steve
Post
by Ga-Steve » Fri May 01, 2020 5:25 pm
I sent a note to DryLok and the representative advised to not use it. Looks like it will be epoxy coated instead.
Posts: 3821 Joined: Thu Jun 10, 2010 11:22 am
Post
by mrintense » Sun May 03, 2020 10:59 am
I'm using Total Bilge which is hard as steel once it's cured, but it does take some time to cure.
Ga-Steve
Post
by Ga-Steve » Mon May 04, 2020 3:44 pm
As of today. Got both coamings done. Not glued and screwed yet. Finally got a used trailer I am having to rework.
Ga-Steve
Post
by Ga-Steve » Wed May 13, 2020 3:11 pm
Coming along. Waiting on trailer parts. Then another shuffle from dolly to trailer.The deck is a little confusing looking at the plans. Steve
footer
Post
by footer » Thu May 14, 2020 6:54 am
Looking good. The nice thing about the top of the boat is you can build it however you want it and it won’t affect the performance of the boat (as long as you don’t change the CG).
But, I encourage you to sign in to GL’s boat building forum umber power boats and post a thread about your build.
