Outrage progress
Re: Outrage progress
Yes on the chines. Don’t know the material you are using bit bending 1” thick oak was not fun. The sheer on the other hand was not too bad.
I have not done the seats. That might be coming up soon. Been looking for a motor. The Stiletto is what I have been looking at for the deck. There are several nice boats with different seat configurations there. Steve
A stripe of paint down the center of the deck would hide that seam as well.
The trick is to block sand on a straight edge it until there is no gap. Then blue tape the seam tight (pull the tape so its acts like a little clamp) before gluing it down. A piece that large is indeed really-really hard to work with. At least you got it down flat! I like Matt's idea to hide the seam with a stripe.
Don't rush the varnish, you should wait at least 2 or 3 weeks after your last coat of epoxy or the varnish won't cure. Maybe 2 part would work sooner but I would not want to rush it after my screw up with 1 part before. The epoxy needs to cure either way I'm pretty sure. Happened to me on my dash, had to strip it all down and start over, SUCKED!!!
Here is a thread on it: https://www.glen-l.com/phpBB2/viewtopic ... 13&t=31269
16' Ski Boat Restoration
17' Overnighter Sloop
Thanks Jim for the tidbits of info.
I did what you said Sunday. I wrestled around in the carport with it cause it was the only place big enough and flat enough. I planed and sanded the edge then butterflied the seam. This pic showed it before I laminated it. Thing is, I must have pulled the two half's to tight. By in the morning, it was starting to wrinkle like they were fighting against each other. My brother and I decided to undo the tape and just do each side separately. The sheets will wrinkle in the blink of an eye if not weighted down. Steve
The “ varnish” I mentioned is really 2part clear from the Glen-L store. System 3 or something like that.
2 days... used about every tool I had. Had to soak the 1/4” ply to get it to bend. Hopefully the 2nd one will go a little quicker. I will not secure until the carpet is down but don’t want to put the carpet down until I am finished gluing and painting. Looks like the floor needs to continue aft. Steve
How do you guys do the deck to hull transition? The instructions say to lay fiberglass over the edge but I painted the hull before the flip. Will fiberglass adhere to the paint or will that have to be removed? I am planning on a rub rail of some sort and that side decking will be painted white to match the hull. Just in the dark here needing advice. I have not glued and nailed yet. Thanks for any help, Steve
for what its worth - on a malahini - I just made sure the deck plywood edges were well covered in thickened epoxy and regular epoxy, then I positioned the rub rail so that it hid this. I didn't use cloth over the edge.
Could you post a pic please? And thank you for the reply. Steve
Hi Steve. Photo below - (before rub rail) - the easier part for me is that I had an additional layer of ~3/8" mahogany on top of the ply...so I don't know that this will be useful for you.
I was looking at some completed stilettos and had noticed a rail/trim around it as well. Probably useful for same thiing, covering deck to hull transition
I used half round rubber from Wefco mfg http://www.wefcorubber.com/extrusions_i ... rounds.asp Much easier to install and cheaper than stainless steel. I couldnt get 1" SS rub rail to follow the sheer, the elevation changes and twist up forward were too much.
Thanks guys. I like the half-round rubber idea.
I have been waiting on my steering wheel assembly from Glen-L so I have not made my dash yet. Apparently it has been back ordered. The clear gloss and another quart of white 2 part paint came in. The center section is sanded waiting on the clear gloss. The wood around the cockpit will be painted clear, as well. Came across a good deal on a motor. But will have to be rewired. I had to change directions on the motor. The money I had been sitting on for the motor ended up going toward my wife’s cataract surgeries. Hence the older motor. Still going to put something down the center seam on the dash. Just have not figured out what Steve
Getting real discouraged. I have been at a standstill on the boat. I have had the steering wheel and assembly ordered since July the 2nd. I have been thinking of calling Glen-L and cancelling the order and just going to a junk yard. But you always get what you pay for. Where did you guys get your steering? Glen-L?
I have been staying busy rewiring the motor. About ready to give it a try. Got some muffs ordered and waiting on an impeller cup. The current cup had shifted or it was installed wrong. 91% humidity today. Boy oh boy! Steve
Got mine on amazon. You can get steering systems on eBay too.
Defender, Jamestown, wholesale marine, etc.
