Installing a strong towing eye
stephenburnett
Post by stephenburnett »
I am trying to figure out how to incorporate a strong towing eye into the laminated plywood stem of the boat I am hoping to build
With three pieces of laminated ply sections making up the stem - what is the best way to approach this considering I will be working with a weak end-grain of the ply ? The eye needs to be strongly attached because of the launch and retrieve methods we are considering
Appreciate any advice out there in Glen-L-Land
Stephen Burnett
Ibrew2be
Re: Installing a strong towing eye
Post by Ibrew2be »
Stephen, the best approach for doing this is with a bow eye that is through-bolted, through the stem. The best approach is to use something such as the stainless bow eye shown in this example:
https://www.amazon.com/Marine-City-Ster ... B07GL4X3G7
Barry
Barry Shantz
Imp built and launched.
Build of Ken Bassett's Rascal currently on hiatus
stephenburnett
Thanks Barry
I was planning to use something similar but I am concerned that bolting through three laminates endwise will not be that strong because it comes through the end grain. What I may do is back the inside with a stainless plate rather than simple washers
Thanks and best regards
Stephen
you can cross-bolts sideways thru the plys, and put a backer plate under the nut
stephenburnett
Thanks again Kens
Ozzieboat
Post by Ozzieboat »
Stephen
Like you I had concerns too. As previously suggested I used a threaded eye with a stainless steel plate under the nut. A cable was then connected to a second hole in the plate using a thimble and the cable was connected to another plate in the same fashion then attached to the stem to keel bolts. The eye is also welded to the cutwater which is bonded and screwed to the hull.
footer
Post by footer »
I used an 5/16”x1.5”x8” U-bolt straight through my Cutwater (it’s not welded to it) and the stem. I made a double flange to keep the bolt from going either way. I literally picked the boat up with it.
My stem is made of two 3/4” ply epoxied and screwed together.
Wont push in or pull through.
Goodell
Post by Goodell »
stephenburnett wrote:
Sat Dec 12, 2020 3:10 pm
Stephen Burnett
in our scenario on the north coast we pull boats out of the surf zone or soft sand areas using a tow-strap attached to the bow eye - then we back into it with a tilt trailer and winch it on. SO there is a lot of force put on it every day. THe Glen-L bowstem system is a little different in the use of longitudinally oriented plywood . Traditional skiffs here usually use a 4x4 or 6x6 cut in half on the diagonal for the bowstem - so there is a lot of material. Everyone here uses a large solid bow-eye (often 5/8" ubolt or a single solid eye with a 3/4" shaft") with a large backing plate and nut on the backside of the stem. To add more purchase area for my laminated plywood stem, I laminated 2x4 fir material on either side of the laminated plywood. Here is one pic of the bottom of the bowstem where it meets the forefoot - to see the laminations on either side.
stephenburnett
Thanks for the examples which more or less confirm what was planning to do. Reinforcing, backing, using robust bracing are all part of my plan
Appreciate the time you have given me
Happy Christmas from Kingston in Canada
Stephen
I used a single treaded bolt through the stem with a big stainless washer on the inside. I’m guessing a crane could hook on the eye and pick the whole boat up without damage.
stephenburnett
Thanks Matt - appreciate your example
Merry Christmas from Canada
Stephen
