Leaving Staples in?
garrys
Leaving Staples in?
Post by garrys »
I am just beginning the plywood covering of my Monaco. From reading the forum I see that most folks are pulling all their staple out after the glue has dried. I'm using a pneumatic stapler with 1/2" narrow crown stainless staples. Even at the lowest setting they are being driven too deep to dig out without damaging the plywood.
What is the downside to leaving the staples in? Of course on the final mahogany strips I'll have to remove them, but why remove them for the "under" layers?
Garry Stout
Tampa, FL
billy c
Post by billy c »
Garry-
i started thinking the same way on my build, but ended up removing them metal mixed with wood was awfully rough to work with when fairing as when you ground the crown off staple legs tear sanding belts and dull tools. also staple legs are very unfriendly to your hands as you work the surface.
-Billy
BruceDow
Post by BruceDow »
Another reason for removing the staples is that they will stick out on the inside of the boat.
Most of your staples should hit frames and battens, but many will not. You will miss some. And there will be places where you need to hold down a stubborn edge between battens.
I did most of my stapling with a plain old "Arrow" manual stapler.
I shot these staples over a string.
Pulling the string would lift them enough that they could be easily removed with "nail puller" pliers.
Where I needed more hold, I used my Pneumatic. Like you, I could not get the setting low enough to leave the crown where I could grap it.
What I ended up doing was stapling over a 1/8" x 1/8" strip of scrap plywood. (staple and snap, staple and snap... each staple only used about 1/4" of length) That left the crown nice and high. The staple and littly plywood spacer could typically be removed in one grab.
You will just need to find a process that works for you. We've all been there.
Bruce.
Dow's Monaco Project
leakcheck
Post by leakcheck »
I haven't been there :oops: :roll: :wink: :? :(
Bob Perkins
Post by Bob Perkins »
PULL THE STAPLES!
1) Stainless only stays stainless when exposed to air, they will break down and cause problems if buried.
2) Don't waste money on Stainless staples - use plain old ones and pull them.
Staple pulling is not too bad to do for those times when you only have 20 minutes. I kept a toilet bowl ring and waxed the staple legs before shooting them in and then removed them once the epoxy set (~12 hours) but before the epoxy was at 100% cure. They came out pretty easily.
If you are going to spend all the time and money - pull the staples - or purchase one of those plastic staple guns. (i.e. Shoots plastic staples just for this purpose) Not really worth the expense to me.. but has been to others.
Good luck on your build
Regards,
Bob Perkins
All the Fun Stuff
upspirate
Post by upspirate »
Boat is looking good Garrys!
I see what some of the people have said since I talked to you.Sounds like better advice...although harder :cry:
leakcheck
Post by leakcheck »
UPSpirate: we won't hold it against you...we all know you're easy !
upspirate
Post by upspirate »
leakcheck wrote:UPSpirate: we won't hold it against you...we all know you're easy !
AWWWW!!!! :roll: :D
WoodBooger
Post by WoodBooger »
This method worked well for me:
[/img]
garrys
Post by garrys »
Thanks to all who responded. Great ideas! I think I'll try Woodbooger's plastic pipe strapping. Any idea where to buy it? Don't know if I've seen it in Home Depot. Same with the "nippers" for removing the staples. It's a rather obscure tool, I think. And last question for Woodbooger.....what is "famo wood"?
Garry Stout
Monaco....Tampa FL
WoodBooger
Garry,
I bought the strapping and the front snippers at Lowe's.
http://www.channellock.com/acb/stores/1 ... ers_C9.cfm
Famowood is just a brand of wood filler.
http://www.eclecticproducts.com/solventbased.htm.
PL wood filler is very similar
http://www.stickwithpl.com/products/det ... oductID=36
Probably any non-water base wood filler would work.
Happy Stapling!
BUNMAN
Post by BUNMAN »
Try using a nylon rope the length of the run you want to do... leave about 6" loose for pulling. Staple the rope down triing to stradle it. To remove, grab the loose end with a vise grip and pull fast and hard - its like pulling a zipper... most all of them will come out. This method save hours x 10!
BUNMAN
upspirate
Post by upspirate »
I saw the nippers at Harbor Freight for 4 or 5$,strapping at Home Depot or Lowes
J Patroni
End cutting pliers
Post by J Patroni »
That type of end cutting plier is common place for ceramic
tile setters. You can find them at any tile supply store.
If you don't build it now, You will regret it later! Already regreting it
Crackerbox Build
http://s232.photobucket.com/albums/ee255/jtpatronimfg/
Checkmate Restoration
http://s232.photobucket.com/albums/ee25 ... 0Starflite
BUNMAN
Post by BUNMAN »
BUNMAN
